N
NICHOLAS MATHER
Guest
So I have a 2 inch ome springs with 1 inch spacers on my 04 TJR. They've been on for about 1.5 to years now.
Just noticed the other day that out of the 4 springs, the front right is sagging easily 1 inch lower than the other 3.
I measured from the bottom lip on the flare to the top of the tread of the tire, on flat ground. All 4 tires are new and are the same. Same rims. All tires set to 26psi, checked immediately before measuring.
I took multiple measurements...I get 5 1/4th on the left side and 4 1/8th on the right side. The rears are each about 5" to 5 1/4-ish.
Any idea what would cause this?
I'm running a warn front bumper and a 9k winch with rope. Nothing has been added to just the right side, nor is there any cargo in the jeep.
I did my best to parking lot measure just the springs bredily before work today and I got something to the effect of 13 on the right side and 14 on the left. Give or take 1/4th of an inch here or there.
Could the spring be pushing itself into the bottom of the spacer? I'm pretty sure I have the order wrong on my spacer- stock pad combo
I've attached pics if it help, hopefully more educated eyes than mine can give me some clues.
FYI, all the dirt and grim you see is from fluid film and winter
Tanks for any help!!!!
