Yesterday while driving my AC was working for 20 minutes then I started to smell something burning (plastic maybe rubber) then the ac stopped working. All the blower speeds still work, new resistor, fan relay, Accumulator, ac lines, fresh charge with 500 micron vacuum. (before all this happened). Pretty sure the compressor was changed by the previous owner and it hasn't been used much. Only thing different I did this drive was try and use my cruise control that never really has worked right, cruise light was on when this all happened but not being used, not sure if that had anything to do with it but it was the only thing different I did this drive. A/C has been working great all summer till now.
Fast forward a few hours the same day, start it up and A/C works for a minute then the squealing started and lasted only like 10 seconds. Fast forward to this morning, I go to start it, no squeal, turn on the A/C and then the squealing started and it was extremely loud. The rad fan wasn't moving at full speed till the squealing stopped 10 seconds later.
