First chart: Both Upstream O2 sensors - Seeing alot of them above .750. This is from my 38 min drive home. chart shows from 20 min to about 23 min.In the O2 data you are looking for the upstream O2 sensors to be between .150V and .750V in closed loop operation. They average target is .490V, but they are moving constantly.
They'll peg at 0.824V -0.845V at WOT once the power enrichment kicks in - about 12 seconds with the stock programming.
and lower
On the fuel side of things you are looking for long term fuel trim (LTFT) values between -5 and +5 in closed loop (partial throttle). The smaller the better. The STFT measure sent to standard ODBII can be weird, but again you're looking for single digits here most of the time in closed loop.
Here is bank 1 and 2. Trim % axis on left, Throttle on right. Seeing some very high long term trims. Same time about 20 mins into drive to 24 min.
It does feel a little rough when I an stopped and idling.
Also attaching raw data with lots of other things
