P.S. the oil pressure sender is screwed into the block adjacent to the oil filter. All you need for this job is a wrench.
I think from now on I’ll be referring to my oil pump as an “oil pressure sender.”
Out of curiosity, why is it referred to as a sender instead of a sensor?
Sensor is the more technically correct term but sender is just a device that sends a signal elsewhere which qualifies in this usage. The two words are commonly interchanged.Out of curiosity, why is it referred to as a sender instead of a sensor? Or is this something that Mopar decided/industry standard
Ah today I learned something new! I always thought the sender referred to the oil pump (OPDA) (probably after reading it's a good idea to replace with the Crown version) but we're talking about the sensor/sender that plugs in nearby
A sensor is something that senses an engine parameter and uses that to provide feedback to the engine computer which the engine computer uses to make adjustments on how it runs the engine. For example, oxygen sensor. Oxygen sensor monitors the air to fuel ratio in the exhaust, and provides that to the computer to help the computer adjust how much fuel it sprays to achieve an ideal ratio.Out of curiosity, why is it referred to as a sender instead of a sensor? Or is this something that Mopar decided/industry standard
Technically it is a sensor because it's not technically a switch despite some parts guides erroneously calling it a switch. The FSM refers to it solely as a sensor, see the below page out of the 2004 FSM, one of many pages referring to it as a sensor. Technically it is 3-wire variable resistor that sends a varying voltage to the PCM to indicate the underlying oil pressure. The oil pressure gauge itself no longer indicate the actual varying oil pressure but nevertheless, the PCM gets the true underlying oil pressure from the sensor. If the PCM determines it's within acceptable limits based on the engine rpm it sends the gauge's indicator to the mid-scale position.An oil pressure switch/sender is not a sensor.
Good flow doesn't mean anything, that could just indicate something like a bad bearing allowing lots of oil to flow around it without everything else receiving adequate oil. That's why cars and Jeeps monitor the oil pressure but not oil flow.BTW, do not confuse pressure for flow.
Put your thumb over the end of a running garden hose; you now have higher pressure, but it provides zero flow.
Technically, we would be better served if they provided us with an oil flow gauge instead of an oil pressure gauge.
Do you think there might be reasons you haven't thought of why the engineers at the various auto manufacturer in the world never included oil flow gauges in our cars or Jeeps or even give us an example of a single modern car from any country with an oil flow gauge? And why those engineers only gave us oil pressure gauges or at least oil pressure idiot lights? It would cost no more to make an oil flow sender than it does an oil pressure sender. Oil flow gauges are important in many industries but they're not used in vehicles because oil pressure is better information to know in an automotive engine.Technically, we would be better served if they provided us with an oil flow gauge instead of an oil pressure gauge.
