Lower Control Arm Torquing
danlow
Los Angeles
I am refurbishing the front-end suspension on my (new to me) 2006 TJ. The lower control arm torque spec is 130 foot-pounds which I barely was able to do on the passenger side where I had plenty of clearance and could push down on the wrench. However, on the driver's side, I will have to push upward since the torque wrench has to point toward the aft end of the car due to the differential. I am not sure I can physically do that to 130 foot-pounds. Any advice? I am using a manual torque wrench and have ordered semi-deep sockets for clearance, so I think I will be able to attach and use the torque wrench with those.
Last ditch, I will torque it as much as I can and ask the alignment shop to finish the torquing when I get it aligned...
Thanks!
Thanks!
Torque it down (in this case up) by hand as best as you can. Then put a jack under the end of the torque wrench handle and jack it up until you get to specs.
Wow, what a GREAT idea!!! I will try it as soon as my semi-deep socket arrives!
Thanks!
Reactions: KcTj
