Got the front bushings swapped out over the weekend. Pretty straight forward. the old bushings looked just fine. The one thing that concerned me was some wear from the oval slots on the axle side control arm brackets. You can see the slot grooved into the bolt barrel ends on the old bushing to the right.
Mostly I guess due from the clamping force and the fact that the hole is a slot, so not sure if there was some movement there or not. I decided to take care of that with some of Blaine's magical washers.
Problem solved.
The ride seems stiffer now. the Kevlar must have changed things. JUST KIDDING! The ride is exactly the same as with the old bushings. Haha!
