I have a 98 Sport with a manual, 2 inch spring lift, Dana 44 rear. Since installing the Dana 44 and a shorter drive shaft my drive train vibrations are very noticeable around 40 - 50 MPH or when accelerating hard. This is expected when you look at the increased and mismatched u-joint angles due to the lift, longer differential housing and shorter driveshaft. I was wondering based on actual experiences if a one inch motor mount lift would solve the problem or do I need to go to a SYE, double cardan shaft, and adjustable upper control arms?
Thanks,
Dan
Thanks,
Dan
