I wanted to check to see if anyone has created a cheat sheet or parts list of what is needed needed to bring an old 8274 up to date with the latest solenoid parts?
I was going to refresh my old winch before putting it on this jeep. Maybe rebuild the brake with all new parts, but mainly interested in updating the motor and going to the single solenoid relay. I know there are several forums that have a full rebuilds, but none I have seen cover the electronic updates in detail. If I recall correctly, the newer 9500 motor will work but needs an updated gear head, the albright type of relay may require a new controller and hook up. I believe the winch is from the late 70s or mid 80s so it is due some TLC.
Anyone completed this task and have any hints or tips? I would appreciate any input you might have.
Thanks,
Thanks,
