@mrblaine what is the point you are trying to make, obviously this is sarcasmAnd if some dirt of some level did happen to make its way into the intake, then what? How does that take out a motor in 10,000 miles?
My point is a bit of dirt in the intake doesn't really do much. Some of ya'll have never run a K&N air filter and it shows.@mrblaine what is the point you are trying to make, obviously this is sarcasm
I ran one one my GMC z71 for about 50,000 miles and had a dirty intake tube everytime I cleaned the filter. That fine of dust may be negligible but is a tiny (if any) performance gain worth the risk of decreasing engine life? I still have one on my 400ex sport quad and it is the same - intake tube always dirty. I left it on the the 400ex since it has mild engine work done and would not run without filter/air box mod's. Unless the factory box is underdesigned or one is going for every last inch of horsepower, why take the chance?My point is a bit of dirt in the intake doesn't really do much. Some of ya'll have never run a K&N air filter and it shows.
Exactly my point. If dirt in the intake kills motors, K&N is responsible for literally millions of dead engines.i'd use a piece of window screen before i'd use a k&n filter. ran 1 on a cummins and wont EVER waste my money on another !
One could easily make the case that larger particles are far less damaging since they can't get by the valve seals and piston rings.I ran one one my GMC z71 for about 50,000 miles and had a dirty intake tube everytime I cleaned the filter. That fine of dust may be negligible but is a tiny (if any) performance gain worth the risk of decreasing engine life? I still have one on my 400ex sport quad and it is the same - intake tube always dirty. I left it on the the 400ex since it has mild engine work done and would not run without filter/air box mod's. Unless the factory box is underdesigned or one is going for every last inch of horsepower, why take the chance?
But the way that filter is rigged up I'd be scared of larger particles slipping through the perimeter seal, big difference between that and running a K&N properly.
Okay so the outstanding question, why run an air filter on an internal combustion engine at all?One could easily make the case that larger particles are far less damaging since they can't get by the valve seals and piston rings.
because it keeps the air filter manufacturers in business. same with the oil filters, thats why i just use a by-pass on mine no filter needed. after all how much dirt can get in the oil ? and just what would those little metal shavings hurt anyway ? as long as you change the oil every 15 or 20k miles it's all good !Okay so the outstanding question, why run an air filter on an internal combustion engine at all?
Are you old enough to remember the standard advertised gospel oil change interval? That's right, 3 months or 3000 miles.Okay so the outstanding question, why run an air filter on an internal combustion engine at all?
Stop storing your pocket change in the air box and that all goes away.You don't actually need to. Of course it will be that one time you don't where somehow a penny or something manages to get sucked into your intake and destroys your engine.
Your showing your age,zorbOil bath air cleaner FTW!
Somewhat serious question: How do oil bath cleaners measure up to other types? I always liked them.
Well... If he happens to drive past the plant that manufactures Aquarium gravel and sucks that into the intake..... it will cause internal engine damage.And if some dirt of some level did happen to make its way into the intake, then what? How does that take out a motor in 10,000 miles?
That's what was used for all motocross bikes in the old days (90s). Oil stops dirt from entering and air too. Didn't effect anything back then when people didn't know any better. People listen to too much internet shit and believe half of it. How else can Biden/Harris be explained?Oil bath air cleaner FTW!
He was referring to "his" oil baths before a particularly good show of his. That's why Mrblaine couldn't afford him.Oil prices are through the roof....baby oil too.Your showing your age,zorb
