I need a motor mount bolt for a 2002 TJ 6.0 drivers side. The one that bolts into the frame. Anybody have any idea what size this bolt is?
Rock Jock Motor Mount Parts List: ??
- Motor Mount Bracket: CE-9201A
- Urethane Motor Mount Bushing Half: CE-9201B
- Steel Bushing Inner Sleeve: CE-9200C
- 3/8 in.-16 x 1 1/4 in. Long Hex Bolt: CE-92620A626
- 3/8 in. Flat Washer: CE-90108A415
- 3/8 in.-16 Nyloc Nut: CE-90630A121
Is there a rubber bushing that goes into the beach
Not sure what you mean. Here is the pic I've added arrows. Unless I did something wrong, This is the Mount, it has a single metal frame that wraps around.So from the pictures it looks like it needs a bushing
So both of those metal pieces under the bolt head are the Motor Mount.
The bolt and a washer I put through the mounts.
Below that I have a 1" motor mount from Savvy, that isn't a bushing, it's a metal spacer to lift the engine 1 inch.
That's all. Not sure what or where you mean bushing, and if I'm not understanding, my apologies.
Thank you clarifying. The riser is what I thought was a bushing. So that bolt just bolts into the frame without a nut on the other end? And that is the exact bolt I need. Can you tell me how long it is, thread type etc. I know it's 3/8 in diameter. Thank you for all the help
Thanks I bought a hardened 10mm at rural king. Only difference between thar one and the one in your picture is the narrow tip part at the end of the bolt
