I recently put a 2” puck spring lift on my tj. Ever since I got a vibration during acceleration. I ordered a 1” body lift and 1” mml hoping to corrrct this. Will this work? Any suggestions? Thanks
Will it effect my trans /transfer case mounts? Like prematurely wearing out mounts?It should get rid of your vibes. The MML raises the engine and lowers the TCase output so that the driveshaft angle is not so steep.
It won’t prematurely wear out the transmission mount.Will it effect my trans /transfer case mounts? Like prematurely wearing out mounts?
Hey, you can always do a TCase drop. A couple of washers might be enough to be vibe free. $2 fixI’m new to the Jeep situation but not to the modification on vehicles situation. I’m aware that it will snowball but just hoping not too much.
It’ll Work. I’m 100% confident.True. My bl and mml are supposed to show up Friday so I’ll find out if it works that night or Saturday.
I just finished my bl last night and got my mml in tonight. Going to torque everything tomorrow and test drive it. My bl said that I do not need to use the transfer case bracket but it looks tweeked to me. I might put it in. Also my stick now hits the shifter bezel. 2nd 4th 6th and reverse. How did you guys resolve that issue?
