PV=nRT
It’s more complicated than I thought. The 20% is much simpler. 25psi cold would be 30psi hot
What if it's 95*out? What if it's 45* out?
PV=nRT
Then everything goes out the window lolWhat if it a full moon??
I'm pretty sure my tires suck!The type of tire your running may just be a bad tire. I don’t have any experience with hankook and I know nobody that runs those personally. With everything you have done comparable to everybody else’s setup that’s the only conclusion I can make. It has to be your tires. The shocks are good based on the consensus here, and I’m running E rated on KM2s and I love my ride. It might be your tires, and that problem you obviously can’t fix without switching brands.
Those are the exact tires I have on my Jeep. The only time I have seen a decent ride with my Jeep was when I had 4 average sized adults in the Jeep. It rode pretty good then. These tires are not designed for such a light rig, plain and simple.I run 265/75-16 Hankook Dyanapro ATM Load Range E tires on my Tacoma, and they were on my JK Sport prior to selling it. I have had no issues with them giving a harsh ride on either vehicle. However, both the JK and the Tacoma are heavier vehicles than a TJ...
Lol I wouldn’t go that far, but the ride quality you describe leads me to the tire itself. A nice all terrain may ride better for you. KO2s or duratracs. Now that’s a whole other debate hahaha.I'm pretty sure my tires suck!
There is a direct relationship between road temp and tire pressure, add braking to the equation and that's the third variable. If anyone thinks they are running their tires at 25 psi think again. Maybe for a few miles then the temp and pressure go up. A TPMS reveals just how much things change going down the road. The opposite is also true. Air down on a hot day. Park it at night come out the next cold morning to a VERY low set of tires.What if it's 95*out? What if it's 45* out?
Last summer I saw 220 degrees in my motorhome. My TPMS alarm was screaming. I forget how high the tire pressure went up, but it was also off the chart.Tires get up to about 200* when hot. Cold they are obviously the surrounding air temp. I’ll try to find the physics formula for calculating pressure increase due to temperature.
Perfect testimony for NOT running load range E tires on a TJ.Those are the exact tires I have on my Jeep. The only time I have seen a decent ride with my Jeep was when I had 4 average sized adults in the Jeep. It rode pretty good then. These tires are not designed for such a light rig, plain and simple.
Then how come everybody else including myself are having zero issues with load E tires. Honest to god if my kidneys were taking a beating everyday I would not be driving on these haha. I have wasted my money on far more dumb shit. If my load range E tires sucked I wouldn’t hesitate to buy a different size. My tj with load E rides amazing and I’ll continue with this ride. The OME lift and 33s is perfect for me. This is such an oppiniated debate that it has to come down to personal preference.Perfect testimony for NOT running load range E tires on a TJ.
Glad to hear that after paying 416 dollars for shocks.I did however feel a significant difference in ride quality leaving hydro's for the Rancho's and even more so offroad.
No I always run KM2sAre you running Duratracs? My Duratracs are load E and they honestly aren’t as harsh as people are making them out to be. Hell, with these Ranchos I don’t think you’d even notice.
Maybe it’s different from tire to tire.
Apparently this falls into the same category as axle gearing for 33" tires, whether you have a manual or automatic tranny. Those that have what they run, swear by it. No one can seem to agree, so as you say, it comes down to personal preference. People seem to run what they do and like it. Sometimes you hear someone say "I hated that setup, and will never run it again"...Then how come everybody else including myself are having zero issues with load E tires. Honest to god if my kidneys were taking a beating everyday I would not be driving on these haha. I have wasted my money on far more dumb shit. If my load range E tires sucked I wouldn’t hesitate to buy a different size. My tj with load E rides amazing and I’ll continue with this ride. The OME lift and 33s is perfect for me. This is such an oppiniated debate that it has to come down to personal preference.
I think it does vary greatly from tire to tire. I went from D rated too E Rated Duratracs and they ride so much better. It would be nice to find a big gathering of Jeepers to compare tires, gearing options, etc.
