I have been reading a lot and and have a few questions from different threads, some here, and other boards. I heard a few times no 2 OBs are the same and i will cycle to verify everything works together. I am just looking for starting points.
On JF there was discussion the lower mount welded in the back of the LCA mount. It looks very tidy, but I don't think it would work with disc brakes. If anyone has a pic from the back of the lower shock mount on a disc Dana 44 I would appreciate if you could post it.
Should the lower shock bolt be 90 degrees to the shaft at ride height?
I've seen a couple here that rebuilt the TB mount. The only pictures I've seen only show it from the outside. It is hard to understand how it was built from that angle. Any pics that show better how it was built would be helpful.
Where does the upper mount end up in relation to the frame rail? Not height, but outboard of the frame or centered?
Thanks
Thanks
