I can give some perspective on that already. One downside to Dynatrac that has hit me before - and is hitting me now - is their use of proprietary parts. The Golden Seal was a good example of that. Now I'm looking at swapping the front rotors to go to 8 lug, and I called them to ask what rotors they use. What they told me is that they build them themselves (no idea if this is true), and I could get them from them for $370 each. A stock rotor off a 1 ton is about $175. My guess is that they use an off the shelf unit, but won't share that info. I'll also need a couple of brackets from them and new cylinders to make everything work, which are also overpriced. But, that is part of the price you pay for the convenience.I would be interested in hearing your take on buying an off the shelf axle like the Dynatrac ProRoc HP60 to building a junkyard axle after you are finished. I am not looking at it from an "enjoyment" perspective, because some of us just like working in the shop and building an axle is just another project n the shop that gives us something to do (working in the garage keeps me out of the kitchen where I eat everything in the pantry). But more from a value perspective. Not sure how to define value; cost is definitely part of it, but so is final product (comparison of overall strength, overall final clearance obtained, etc...), I would say that availability of parts during and after build would also be a factor.
From reading your build you would have to do all the custom brackets yourself anyway, nothing would be bolt in. But at one time it appears that you did go off the shelf with the Dynatrac, then modded off the shelf, and now are building from junkyard. Think it would be a good perspective to hear. I will most likely be in the market to upgrade my axles in the future and while building my own axles appeals to my "want" to build my own, I also don't want to end up with a big oil tank that not only gets caught on everything but also cost me twice as much and I can't find parts for down the road.
I've also had problems getting replacement shafts from them in the past. I've bent two shafts and broken one. A few years ago I broke the chromo shaft I originally got from them, but when I called to get a replacement it was something like $1300 and was going to take 6-8 weeks to get it. It also took almost two weeks to get that answer as I recall. I bought a chromo replacement from ECGS for about $250.
All that having been said, I was very close to pulling the trigger on their new HD60, which would have been close to 8 grand. For me it's not so much about the money (I'm well into six figures in parts on this thing as it sits), but I do enjoy a good project. On the 14 bolt the only thing I'm using from the junkyard is the housing - everything else is getting replaced so it's not a budget build by any means. I'll be at about 4 grand just for the axle when all is said and done. But like you, I enjoy being in the shop. More than that, I take a lot of pride in building things myself. Honestly, for that reason a small part of me has always regretted buying the ProRocks as opposed to building them myself - so maybe I'm playing a little catch up.
One very good thing about the Dynatrac will be its resale value when I sell the thing. The name does add value there.
At the end of the day, I think the shaved 14 bolt with the milled ring gear is only going to give up about a 1/2" in clearance to the Pro-Roc. On 40's I'm good with that. It will also be a good bit stronger, and will hopefully hold up better behind all the ponies. And, it'll be fun. I'm already enjoying the project. We shall see if that lasts...
