I am always AMAZED at the work you do and the things you come up with to accomplish it.
Thanks pal.I am always AMAZED at the work you do and the things you come up with to accomplish it.
You’ll need spindles to support them.I'm also looking into doing 40 spline shafts
I did look into that, but decided to stay with the 30 spline stuff - didn't really know how I would cut off the old spindles and accurately install the larger ones.You’ll need spindles to support them.
After finishing up the welding last night I was catching up on a buddy's build thread over on JF (Chris's - 92VegasYJ). He was talking about how his axle is bent and was working on getting it straightened out - and I freaked. Did I throw enough heat at the 14b to bend it? I realized that I should have checked the axle for straightness prior to all the work - but I did not. So, better now than never.
To check his, Chris used a set of 3D printed pucks he got from a guy on youtube who posted a video on how to straighten a '60. After seeing that, I came up with a way to build a set of pucks myself.
First up, I made two end pieces which would fit snug around the spindles, with a hole for a string dead center.
Then I used one of the bearing races as a template to cut the center puck, marked it for center, and cut a small slot for the string to pass through. Here it is all set up:
