Man - you guys don't even give me a chance to finish typing!So what's the word? Is it straight?
To get a measurement, rotate the disk so that the string is centered in the slot - and that line points toward the bend. And sure enough - it's out. 70 thou by my measurement. About 1/16".
View attachment 218002View attachment 218002
But - it's bent in the opposite direction I would have expected from heating the case. If excess heat had caused the case to contact on the side of the new cap, it should have pulled the tubes toward that side of the case. The bend goes in the opposite direction. So maybe this was there all along? I really wish I had checked before cutting into the case.
So help me out - what is close enough? I've heard these axles don't come out of the factory dead straight, but I don't know how much would be acceptable. Should I be straightening this thing?
No error in the setup, I don’t think. Dead center on the spindles, and dead center in the carrier bearing. Where do you see there might be an error, Trev?.070" isn't too bad I don't think, but I also think there might be that much room for error in your measuring setup though, hard to tell
Did you check to see if your holes in the pucks for the wheel ends where the wire passes through are concentric to the OD of the puck? That plus how tight of a fit the end is around the tube could mean your wire isn't quite centered in the end of the tube.No error in the setup, I don’t think. Dead center on the spindles, and dead center in the carrier bearing. Where do you see there might be an error, Trev?
I purposely made the pucks to be tight to the spindle, and to the bore for the carrier bearing. 0 play in each. And yes, the holes in the end pucks where the sting passes through are dead center to the OD. Easy to do with a circle. Note that the center puck is secured with the carrier bearing locks. Also, the hole in the end pieces is the exact diameter of the string - that actually made it a pain in the ass to get the string through, but that makes the string dead center.Did you check to see if your holes in the pucks for the wheel ends where the wire passes through are concentric to the OD of the puck? That plus how tight of a fit the end is around the tube could mean your wire isn't quite centered in the end of the tube.
It looks like the you were coming up with the .070" measurement based off the size of the gap between the edge of the wire and the end of the slot closest to centerline? You'd have to know if the centerline of the radius in the slot is concentric to the OD of the puck and take into account that radius and subtract it from the .070".
Most of the error I think would come from the accuracy of the slotted puck, as the other pucks would have to be off quite a bit at the end of the tube to give you .070" at the diff.
I do really like this method of checking for straightness though, I haven't seen it done like this before and it's certainly a lot cheaper than buying a chrome bar. I'd be curious to see what kind of a measurement you'd get with some pucks machine to fit the tubes nicely. If you're interested, they'd be pretty easy for me to make with a few measurements off of the axle
Yeah I was thinking about it some more. Might be worth trying it with the string secured at the far carrier bearing, running the other carrier bearing and secured at the wheel end, then flip it around to check the other tube. I think that would give a more accurate measurements of the tube to the differential instead of both of the tubes as a whole. Otherwise both tubes could be bent in counteracting directions that wouldn't be measured correctly going off of the slot.I purposely made the pucks to be tight to the spindle, and to the bore for the carrier bearing. 0 play in each. And yes, the holes in the end pucks where the sting passes through are dead center to the OD. Easy to do with a circle. Note that the center puck is secured with the carrier bearing locks. Also, the hole in the end pieces is the exact diameter of the string - that actually made it a pain in the ass to get the string through, but that makes the string dead center.
Thanks for the offer in the machined pucks.
Considering you're using a squirt gun, why not source an alignment rod?After grinding the welds smooth (again with the grinder...), I mocked up the truss on the newly dead straight axle. I can tell this is going to take a bunch of tweaking to get it to lay down correctly. But, it is definitely beefy. The top plate, pinion guard support, and pinion guard are all 3/8". Ain't gonna be light...
Squirt gun?
Yup - just not sure how that relates to an alignment rod.You're mig welding, right?
End caps and an alignment rod would help keep the tubes straight since youre putting so much heat into it and not using a tig machine to control heat.Yup - just not sure how that relates to an alignment rod.
Gotcha. Now that makes sense. Thanks.End caps and an alignment rod would help keep the tubes straight since youre putting so much heat into it and not using a tig machine to control heat.
You could always use both.Gotcha. Now that makes sense. Thanks.
So what’s cheaper - an alignment rod or a TIG welder?
