Boy I tell you. I wear a helmet when I heat up a ring gear in case she catches me in action!
I saw recently on GrindHardPlumbing, he bought a used oven for $75 and put it in his garage to bake his wheels. That or finding a cheap toaster oven off Temu would be better insurance than risking your life for our hobby.![]()
You've not lived until you have to draw down 120 foot pounds on a rotating carrier body...
So Jeff when I get ready to regear my Dana 44 F&R will you give me a crash course??????![]()
Well Johnner, I've now had two failed installs - you sure you want my advice???
Your 10 and 5 pattern looks good to me - it's centered nicely heel to toe, and isn't at all close to being "shallow", though I do what Crowne does an tend to go for a deeper pattern (esp on something like a 14B where you know your pinion is staying damn solid). That said, I would have little worry running the pattern you got, especially considering the alternative.
Interestingly enough, I ran into the same issue on my 14B regear, where 10-thou was all I had for "thin" pinion shims as well (my Motive kit came with .010", .011", .013", .015", .017" & .019"). This seems to be common and is why many 14B regear people will often automatically throw a shim under the pinion gear to give them a tad more flexibility (most throw on a 10-20 thou shim though, not 50). I wouldn't spend the time to fiddle with a 50-thou shim, since you're probably only 1-2 thou off "perfect" to begin with. I'd find something that would let you run 1-2 pinion shims that you already have
And here we go. The previous setup ran a 15 thou shim stack on the pinion housing, and the backlash was 5 thou. To give myself a wide bracket I started with 0 shims, and 6.5 thou for backlash:
I think it's just a little deep - which is good news as I can't go any deeper without adding shims to the actual pinion gear. But as always, I'm looking for some feedback.
To finish the bracket, next I went to a 16 thou shim stack on the pinion, which gave me 5 thou on the backlash.
This looks shallow, so if Mike ( @hosejockey61 ) can confirm that I'm too deep at 0 and too shallow here, I think I've bracketed the setup.
Yes I do! My next question was going to be exactly that. I can't remember if you mentioned it yet.Mike - remember that damned 2-Cut vs. 5-Cut mess when I did my old '60?
OK - help me with a quandary. My smallest pinion housing shim is 10 thou. Every 14-bolt shim kit I see for sale starts at 10 thou. That means I can't go deeper without pulling and breaking down the pinion housing, pulling the outer pinion bearing, and adding a shim. I do have shim that I think will work, and can be pressed on with the bearing, but the smallest I have there is 50 thou. That would them mean going with 40-50 thou of pinion housing shims to be able to go a few thou deeper than I am now. Or, looking to find a thinner shim that would work on the pinion gear.
So, how does the setup at 10 thou and 5 backlash look? Is it worth running, or should I consider the "shim the pinion gear" route to get a little deeper?
