I'm thinking it's still just slightly shallow. I'm curious to hear what Been has to say. I think you are close there....maybe within 2-3.
My thoughts too - but getting there...
How does it all feel with the new gear installed? Does it feel anything like what you had in there before when turning it by hand?
Here is a side-by-side comparison of the last drive side pattern I did prior to adding the pinion shim, compared to the current:
Man, I'll say it again. The pattern is so much easier to read on these Crowne Racing gears compared to the Yukons.
10, 5, 49, 7.........220, 221...whatever it takes...(bonus points for naming the movie...)
The 10/5 pattern looks slightly shallow and the 49/7 pattern looks slightly deep (maybe what you were looking for?)
How many thou difference between those two patterns do you think?
You want a beer? It's 7 o'clock in the morning... A scotch???
Based on what the Crowne guy told me, I want to be on the deep side - but not so deep as to cause problems.
Know where I should go if I need to borrow a C clamp !!
Base on what I did with the new pinion gear shim, my guess is that there is 2, maybe 3 thou between those two patterns.
As I said, I was thinking about adding a thou (going shallower) to see what that does, and I think that would put me 1, maybe 2 thou deeper than the 10 5 pattern.
Mike - do you think it would cause problems if I stayed with the deeper 49 7 pattern?
I also have a note into Crowne guy, but don't expect to hear from him until maybe tomorrow. I'm certainly not in a hurry to button it up.
If you're within 2-3 thou, my guess is that you will be good - but with your history who knows![]()
I know your shim selection doesn't give you a whole lot of options, but I always strive to find the best pattern and then make my decision on which one to use. So, if you're deep now, is there still a "better" deep option? You won't know unless you check.
But that's easy for me to say when I'm only dealing with sissy Dana 30's and 44's.
If you're not in a hurry, I would wait and see what Ben says simply for the fact he is the one that will warranty it. If you're within your 1-2 thou being deep, then that's probably where you want it.
