A long time ago, prior to getting my big diesel tow rig and 10k pound trailer, I hauled the Jeep around behind a 1/2 ton Yukon XL on a 7k pound trailer. On that rig I ran a load bearing hitch - because it needed it to handle the weight. The big Ford - not so much. So I've always just straight bumper pulled the current trailer. I also run a set of air bags to recover the 1" the rear drops when I load up the rig.
Although I've never weighed it, I estimate the current trailer all loaded up runs between 9 and 10k pounds. It works very well as I've got it pretty much dialed in, and I've made many successful and comfortable cross-country trips with this setup (blown tires and broken shackles not withstanding...
Here she is all loaded up:
A short while ago I was having a discussion with my buddy Ryan (
@Apparition) about running air bags as opposed to running a load bearing hitch. Since I still have my old load bearing hitch, the conversation triggered a thought: I wondered if running that hitch would improve an otherwise already good towing setup. I'm heading out to Moab in a few weeks, so I thought it would be worth a try. You know, to quote JJ (
@jjvw), "For Science!"
So I dug the old hitch out of storage to install it on the trailer. The first thing I had to do was to modify two of the brackets to clear the storage box on the tongue. It was my first opportunity to use to the new band saw on metal. And oh man, it cut through it like butter. I absolutely love this thing.
Then it was just a matter of some measurin' and cypherin', a few holes in the tongue, and it was in:
A great feature of this hitch is that it has built in sway control - that's the purpose of that extra bracket in the center of the assembly. It made a huge difference behind the old Yukon.
Finally, I spent some time getting the hitch set to level the truck and the trailer. Then I took it for a long highway test drive, and to my surprise it made a difference. Zero sway, even when I deliberately swerved at highway speed, and a bit less hobby horsing. The steering even felt a little less light. To make sure I was not butt dynoing the results, or getting a placebo effect, half way through the drive I stopped and pulled the bars, and got back on the same highway. As good as it was before behind the big truck, there was definitely an improvement.
My final assessment is that it would not be worth the extra setup time for a short, local trip - say under a couple of hours - but it will definately be worth throwing it on for the trip to Moab.
Thanks Ryan.
