B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
When I reinstalled the old gear, I took some time to take care of a small nit. When last I built this steering, I wound up with my pitman arm being a little off center when driving straight. I don't think it caused any problems and did not limit the steering travel in any way, but like many little things it just irritated me. It was off by a tooth or two.
So, I centered the arm and shortened my drag link just a bit to accommodate. It required breaking out my very expensive 7/8x18 Left Hand Tap to sink the threads just a bit further - well at least now I've gotten to use the thing twice....
And back in it went:
Although the TRE's on the drag link were fine, the last time I smoked the one on the pitman arm side I installed my spare. This effort reminded me of that fact, so I ordered a spare to carry on the trailer.
The Moog part number I've used for this TRE is ES3096L. It's actually the stock TRE for this location. However, when I put them side by side, I see this:
The TRE I'm currently running (the one on the right) is noticeably thicker at the joint than the new one. Does anyone know if there is a heavy-duty version of this TRE, or perhaps Moog has changed the design? Or maybe the one I'm running now is an OEM part and is actually thicker?
Any insight is appreciated as always.
You might see if Parts Mike has a version.
