I am new to
wranglertjforum.com, but not new to Jeep's or forums in general. I've spent a good bit of time over on..., well..., let's just call it
thatotherjeepforum.com. Lately though, it's become more and more quiet with not nearly the activity as when I joined many years ago. Come to find out, a lot of my old virtual buddys have come over here. I was introduced to this forum by a good virtual buddy,
@TheBoogieman, and after spending a few weeks here, I've noticed quite a bit more activity, and I've seen many of my buds from back in the day.
It's hard leaving behind a build thread covering many years, over 2,500 posts, and about a quarter million views, but this seems to be the place to be. So after a little prodding from my buddy Rick (
@Wildman) I'll start off this thread as a bit of an introduction, a quick summary of what I've done to the rig over the past fifteen years, and new mods going forward.
First, a bit of background. My current rig is a 2004 wrangler unlimited which I bought new back in 2005. This is my 4th Jeep. My first vehicle was a 1971 CJ5, with the 225 Buick Dauntless, Odd Fire V6. It would pull the front wheels off the ground going forward - and pull the side wheels off the ground going around a corner. It was a death trap - but you don't know that when you are 16.
And here it is - my sister always called me a Jeep Creep - so the name stuck. Since this rig, I've owned a 1982 CJ7 Laredo, and a couple of Cherokees. But I had been out of Jeeps for a while, before deciding to get back into it with my current rig.
On thing I should definitely have done over at that other forum was to create an index to more easily locate my projects. It got so big that I was having trouble locating things, so I will take that as a lesson learned and create and try to keep up an index here on this first post.
Introduction - - - - - - - - - - - - - - - - - - - - - - - - Post #1
Summary of First Mods - - - - - - - - - - - - - - - Post #4
Coilover Suspension Summary - - - - - - - - - Post #6
Moab Shots - - - - - - - - - - - - - - - - - - - - - - - - Post #15
Supercharged I6 - - - - - - - - - - - - - - - - - - - - Post #33
392 Hemi - - - - - - - - - - - - - - - - - - - - - - - - - - Post # 36
Hemi Exhaust - - - - - - - - - - - - - - - - - - - - - - Post #40
Hood Louvers - - - - - - - - - - - - - - - - - - - - - - Post #42
Cowl Intake - - - - - - - - - - - - - - - - - - - - - - - - Post $45
Dyno Testing - - - - - - - - - - - - - - - - - - - - - - - Post #47
Swag Off Road Body Mounts- - - - - - - - - - - Post # 64
Custom Console Considerations - - - - - - - Post #95
Team Hunt's Overlander Ladder - - - - - - - Post #114
Trailer WIring Plug - - - - - - - - - - - - - - - - - - Post #127
My Grandson - LJ - - - - - - - - - - - - - - - - - - - Post #131
Smoked Pro Rock 60- - - - - - - - - - - - - - - - - Post 135
Pro Rock 60 R&P and ARB Repair - - - - - - - Post #140
Pinion Wrench Tool - - - - - - - - - - - - - - - - - Post #167
Turkey Carving Tool - - - - - - - - - - - - - - - - - Post #181
Jeep Toy Box- - - - - - - - - - - - - - - - - - - - - - - Post #196
Final Pro Rock Gear Pattern - - - - - - - - - - - Post #247
Shaved 14 Bolt Rear Axle - — - - - - - - - - - - Post #254
Shaved 14 Bolt - Take 2 - - - - - - - - - - - - - - Post #293
Straightening the 14 Bolt - - - - - - - - - - - - - Post #337
14 Bolt Truss - - - - - - - - - - - - - - - - - - - - - - Post #350
14 Bolt Gear Setup - - - - - - - - - - - - - - - - - - Post #403
14 Bolt / Pro Rock 60 Side by Side - - - - - - Post #447
Gas Tank Lift and Tuck - - - - - - - - - - - - - - - Post #471
Shaved 14 Bolt Ready for Install - - - - - - - - Post #476
14 Bolt Brake Lines - - - - - - - - - - - - - - - - - - Post #480
Pro Rock 60 Front 8 Lug Hub Conversion - Post #495
Laser Alignment - - - - - - - - - - - - - - - - - - - - Post #505
Cutting Parking Brake Cables - - - - - - - - - - Post #506
Tire Carrier Modification - - - - - - - - - - - - - Post #511
14 Bolt First Drive - - - - - - - - - - - - - - - - - - - Post #530
Midland MXT 275 Install - - - - - - - - - - - - - - Post #534
Cutting Parking Brake Project - - - - - - - - - Post #540
Tuffy Underseat Storage Box - - - - - - - - - - Post #560
Rampage Frameless Top - - - - - - - - - - - - - Post #561
Tailgate Repair - - - - - - - - - - - - - - - - - - - - Post #565
Moab 2021 - TJ Fest - - - - - - - - - - - - - - - - - Post #611
Trailer Roadside Repair - - - - - - - - - - - - - - Post #620
Trailer Suspension Repair - - - - - - - - - - - - Post #634
Moab 2021 GoPro Video - - - - - - - - - - - - - Post #658
Colorado Backcountry Trip - - - - - - - - - - - Post #758
Hydro Steering Mount Repair - - - - - - - - - Post #805
Northeast BDR ADV Motor Trip - - - - - - - - Post #816
Door Surround Removal Mod - - - - - - - - - Post #821
Cage Mod for Rampage Top - - - - - - - - - - Post #840
VanLifeDesign Picture - - - - - - - - - - - - - - - - Post #850
392 Hemi Tune - Take 2 - - - - - - - - - - - - - - - Post #851
AFR Gauge Installation - - - - - - - - - - - - - - - Post #852
Laptop Desk for Data Logging - - - - - - - - - Post #873
Hawk Pride Off Road - September '21 - - - Post #879
AOP - September '21 - - - - - - - - - - - - - - - - Post #913
Driveshaft Carnage - - - - - - - - - - - - - - - - - Post #917
Top Repair - - - - - - - - - - - - - - - - - - - - - - - - Post #930
Antenna Replacement - Chrome No-Mo - Post #935
Trailer Tires - - - - - - - - - - - - - - - - - - - - - - - Post #940
Driveshaft - Beef Version for the Rear - - - Post #941
Higher Volume Radiator Fan Needed - - - - Post #961
Spal 500 Watt Brushless Fan Install - - - - - Post #971
Hidden USB Port - - - - - - - - - - - - - - - - - - - - Post #988
A/C Fan Override - - - - - - - - - - - - - - - - - - - - Post #1,028
Band Saw Upgrade - - - - - - - - - - - - - - - - - - - Post #1,042
The "Look at Me!" Wall - - - - - - - - - - - - - - - - Post #1,063
Amplifier - - - - - - - - - - - - - - - - - - - - - - - - - - - Post #1,087
LED Backup Lights from Claytone - - - - - - - - Post #1,213
Hawk Pride ORV Park 3-5-2022 - - - - - - - - - - Post #1,214
New 59 psi Fuel Pump for the Hemi - - - - - - Post #1,244
Trailer Tongue Weight - - - - - - - - - - - - - - - - - Post #1,294
Moab - TJ Fest 2022 - - - - - - - - - - - - - - - - - - - Post #1,305
Tool Rolls - Comparison and Selection- - - - - Post #1,366
PSC Steering Gear Replacement - - - - - - - - - Post # 1,387
PSC Steering Gear Replacement - Round 2 - Post # 1,418
Trailer Tongue Lock - - - - - - - - - - - - - - - - - - - Post # 1,434
Toy boxes for the Grandkids - - - - - - - - - - - - Post # 1,545
Hawk Pride December 2022- - - - - - - - - - - - - Post # 1,549
Trailer Tongue Lock Enhancement - - - - - - - Post # 1,555
Wide Band O2 Test and Replacement - - - - - Post # 1,571
Swing Out Tire Carrier Frame Tie-In Repair - Post # 1,582
Maxxis Razr Tire Warranty Replacement - - - Post # 1,601
Truck Hitch Pin Security Solution - - - - - - - - - Post # 1,672
Moab 2023 - - - - - - - - - - - - - - - - - - - - - - - - - - Post #1,706
Moab 2023 / Damage Report - - - - - - - - - - - - Post #1,734
Moab 2023 - Devil's Hot Tub Roll - - - - - - - - - Post #1,735
Moab 2023 - Roll Recovery - - - - - - - - - - - - - - Post #1,742
Tail Gate Repair - - - - - - - - - - - - - - - - - - - - - - - Post #1,763
Grille and Front End Repair - - - - - - - - - - - - - - Post #1,806
Cooling System Upgrade - - - - - - - - - - - - - - - - Post #1,880
Front Lower Control Arm Replacement - - - - Post #1,901
LJ in the LJ - - - - - - - - - - - - - - - - - - - - - - - - - - - Post #1,913
New Rampage Top (Again) - - - - - - - - - - - - - - Post #1,918
A/C Accumulator Replacement - - - - - - - - - - Post #1,946
South African Witch Doctors Surgery - - - - - Post #1,982
Redline Goods Steering Wheel ReCover - - - Post #1,996
R/C Rock Crawler - - - - - - - - - - - - - - - - - - - - - Post #2,035
Track Bar Rebuild - - - - - - - - - - - - - - - - - - - - - Post #2,064
Front Coilover Spring Replacement - - - - - - - Post #2,087
Rain Cover Mod - - - - - - - - - - - - - - - - - - - - - - Post #2,090
Skid Plate Nutsert Replacement - - - - - - - - - - Post #2,106
Engine Skid Reinforcement - - - - - - - - - - - - - Post #2,112
Hawk Pride with Victor- November 2023 - - - Post #2,124
Odyssey Battery Replacement - - - - - - - - - - - Post #2,136
Atlas Shifter Cable Replacement - - — - - - - - - Post #2,157
Pool Filter Wrench Build - - - - - - - - - - - - - - - - Post #2,186
Winch Controller Plug for Grille - - - - - - - - - - Post #2,193
Atlas Shifter Cable Repair (Take 2) - - - - - - - Post #2,205
Front Spacers and Scrub Radius Issues - - - Post #2,217
Tie Rod End Replacement - - - - - - - - - - - - - Post #2,219
Air Filter Replacement - Fail #1 - - - - - - - - - Post $2,230
Triple T-Case Shifter Arrives - - - - - - - - - - - Post #2,267
Colby Emergency Valve Stemp Repair Kit - Post #2,272
Bottle Jack Accessory Build - - - - - - - - - - - - Post #2,276
Lose the High Lift!!!! - - - - - - - - - - - - - - - - - - Post #2,278
Air FIlter Replacement - Success!!!! - - - - - - Post #2,288
Seat Riser Project for Boston Whaler - - - - Post #2,291
Broken J-Joint Repair - - - - - - - - - - - - - - - - - Post #2,308
Dynatrac HD Ball Joint Assessment - - - - - - Post #2,327
Triple Shifter Machining Mod - - - - - - - - - - Post #2,352
Center Console Design - - - - - - - - - - - - - - - Post #2,365
American Iron Ball Joint Eliminators - - - - - Post #2,370
Ball Joint Eliminator Install - - - - - - - - - - - - Post #2,384
Bottle Jack Accessory Sleeve - - - - - - - - - - - Post #2,405
Gigantic Wall Cabinet Build - - - - - - - - - - - - Post #2,407
Wiper Motor Assessment / Replacement - Post #2,409
New Tow Pig Setup - - - - - - - - - - - - - - - - - - Post #2,411
Front Axle Tie Down Hooks - - - - - - - - - - - - Post #2,466
Tow Pig Backup Assist - - - - - - - - - - - - - - - - Post #2,512
GMRS Antenna Replacement - - - - - - - - - - Post #2,535
Moab 2024 Front Truss Repair - - - - - - - - - Post #2,537
Moab 2024 - Wheelin' Videos - - - - - - - - - - Post #2,551
Welding Hood Lense Replacement - - - - - Post #2,578
Gluetread Tire Sidewall Patch Test - - - - - - Post #2,586
Breakin' Bead - (with the High-Lift) - - - - - - Post #2,598
Shoulder Harness Quick Release Mod - - - Post #2,605
Moab Front Truss Repair - Take 2 - - - - - - - Post #2,624
GMRS Antenna Tuning - - - - - - - - - - - - - - - Post #2,633
Detached Intake Repair - - - - - - - - - - - - - - Post #2,634
Tow Pig Lift! - - - - - - - - - - - - - - - - - - - - - - - Post #2,639
Thomas' Dynatrac Axles and Hemi - - - - - Post #2,640
Bye, Bye Old Tow Pig - - - - - - - - - - - - - - - - Post #2,648
Steering Wheel from Poland! - - - - - - - - - - Post #2,667
Jeep. Tow Pig and Trailer Weights - - - - - - Post #2,675
GPS Tablet Selection - - - - - - - - - - - - - - - - Post #2,703
Trailer Tongue Weight - - - - - - - - - - - - - - - Post #2,704
GPS Tablet Install - - - - - - - - - - - - - - - - - - Post #2,722
Hawk Pride with Victor - November '24 - Post #2,764
Victor's Hawk Pride Poem - - - - - - - - - - - - Post #2,775
Hydro Assist Hose Repair - - - - - - - - - - - - Post #2,786
Kenwood Stereo (After Cooler Incident) - Post #2,789
Dog Toy Boxes - 2024 - - - - - - - - - - - - - - - Post #2,801
LJ's Matching Tattoo - - - - - - - - - - - - - - - - Post #2,811
Caleb & Riley's Toy Boxes - 2024 - - - - - - - Post #2,839
Drawer Unit Storage Bench - - - - - - - - - - - Post #2,842
Sissy 14 Bolt Eats a Pinion Bearing - - - - - Post #2,844
Checking if the 14 Bolt is Straight - - - - - - Post #2,918
14 Bolt Gear Install - - - - - - - - - - - - - - - - - Post #2,928
Weighing the 14 Bolt - - - - - - - - - - - - - - - - Post #2,995
Hammer Drawer Organization - - - - - - - - Post #3,010
Maxxis Trep Stickies - - - - - - - - - - - - - - - - Post #3,043
Bead Buster - - - - - - - - - - - - - - - - - - - - - - - Post #3,071
Mounting the Treps on Bead Locks - - - - - Post #3,081
Treps and Tire Shine! - - - - - - - - - - - - - - - - Post #3,148
Hard Facing (Sort of) the 14 Bolt Diff Cover - Post #3,177
Hu
Hood Catch Guard from Cole - - - - - - - - - - Post #3,223
Rampage Top Rear Zipper Repair - - - - - - - Post #3,226
Off Road Jack Build - - - - - - - - - - - - - - - - - - Post #3,228
Trailer Box Organization for Jack - - - - - - - Post #3,239
AOP with Victor - March 2025 - - - - - - - - - Post #3,263
Jack Stand mounts for Trailer - - - - - - - - - - Post #3,275
Hitch Vise for Trailer - - - - - - - - - - - - - - - - - Post #3,285
