Are you saying it's not the cat's ass?
Why do you have to run coil over to get the full benefit of a high line?+1 for aluminum GR. I belive @Plumber1 has the non HL PS on his in this photo. View attachment 286060
I'm sure you're aware but you're going to need to extend the shock mounts and ideally run coil overs to get the maximum benefits.
For the high travel situations COs are beneficial because they keep the spring aligned throughout the travel as the shock moves in the mount.Why do you have to run coil over to get the full benefit of a high line?
Adding to what @rasband said, on my jeep I have 11" shocks upfront with a 6/5 bias to uptravel. When flexing out I still don't get to the top of the fender and likely could raise it another inch. (Total guess) So 7/4 may work in my case but I'd lose droop. With the fancy shocks @jjvw has it may not be as bad because you could run 7/5 but it's still a compromise. If you put 14" coil overs in you'd have 7/7.... I'm not personally concerned at the moment since it's not an issue currently but if I was starting over I'd highly consider getting 14" coil overs and pushing the wheelbase forward a bit like @jjvw as well. Not because of interface issues with the tires but to increase the approach angle.Why do you have to run coil over to get the full benefit of a high line?
I bent my passenger side tub with the OEM fenders causing the replacements to not sit quite right on that side. It's all about how you land on what's there, obviously it's harder to catch what isn't there.Careful with highline or aftermarket steel fenders. I have a few friends with bent tubs because of them. Ones with sizeable flares anyway.
I know you can bend the tub with factory fenders but that kind of proves my point. A lot of after market fender makers tout stronger fenders or it is at least implied. If the stock sheet metal fenders can bend the tub, image how bad that tub dent might have been if you had them tube boys on there at the time.I bent my passenger side tub with the OEM fenders causing the replacements to not sit quite right on that side. It's all about how you land on what's there, obviously it's harder to catch what isn't there.
Did you see Blaine’s picture where he trimmed a Crawltek fender since his tire was hitting it?For the high travel situations COs are beneficial because they keep the spring aligned throughout the travel as the shock moves in the mount.
But I'll be testing how much I can use in my highlines next week. I don't expect the spring is the deciding factor.
Can you tell me what bikini top you’re running in this picture? Looks great, I’m wanting one of those for my LJ. Thanks
I'm not sure I did, do you happen to have a link or picture? I don't expect to on my 35s but it's possible with the travel I'm chasing (especially when 37s materialize).Did you see Blaine’s picture where he trimmed a Crawltek fender since his tire was hitting it?
I can’t recall where I saw it. But I may have to do it to mine.I'm not sure I did, do you happen to have a link or picture? I don't expect to on my 35s but it's possible with the travel I'm chasing (especially when 37s materialize).
If it's the two rigs I'm thinking of, I believe those are on 40s.I can’t recall where I saw it.
Pretty sure they areIf it's the two rigs I'm thinking of, I believe those are on 40s.
it look-a like-a Bestop (or similar) Safari topCan you tell me what bikini top you’re running in this picture? Looks great, I’m wanting one of those for my LJ. Thanks
I was thinking rampageit looka likea Bestop (or similar) Safari top
ConfirmedI was thinking rampage
