At this point you just need to swap out that 4.0 for a Hemi and see if that solves your issues
Sure, throw more money at it and it'll go away, right? Lol!
hub kit is on saleAt that point, I'd buy a stock rig and swap parts until you have your old rig again vibe free (but maybe undergeared).
I've considered gearing up to 4.10's, and or going to larger tires to slow the DS down some. Tired of throwing money at it.
I have on occasion mentioned that. I have on every occasion been soundly told I was full of shit.An observation I've made a few times with MC is that there is a noticeable amount of axle wrap from the softness of the bushing. I can't help but wonder if this is contributing to some of the driveline vibes more than a few are forever chasing.
Movement is movement. But it's been ruled out, so maybe we are.I have on occasion mentioned that. I have on every occasion been soundly told I was full of shit.
Theoretically, you should be able to tune out the vibrations caused by axle wrap out via pushing the pinion angle down when static, no? Then when you hit the highway the axle wrap and lowered pinion angle counteract each other to create the correct angle. The whole theory seems like a bit of a stretch to me. That might be an easy test? Obviously you wouldn't want to leave it that way long term.
Quite possible. Here is what I do know for certain. The rear pinion is very unforgiving when it is set high. Under load, the lowers are in tension, the uppers are in compression. That is the exact direction one would move them to raise the pinion. Shorten the lowers, lengthen the uppers. If you have a sensitive rig, you don't want that happening and then the challenge becomes to find the angle that doesn't vibe when it is low enough at slow speed to not rise past the sweet spot when the load comes on. A lot of folks also don't understand that a vehicle with the aerodynamics of a brick uses a lot of horsepower to just maintain speed and that is a higher load on the arms. Higher load is more potential for displacement.Movement is movement. But it's been ruled out, so maybe we are.
You are correct but if you get it too low in order to combat the rise in pinion angle, that will cause vibes as well.Theoretically, you should be able to tune out the vibrations caused by axle wrap out via pushing the pinion angle down when static, no? Then when you hit the highway the axle wrap and lowered pinion angle counteract each other to create the correct angle. The whole theory seems like a bit of a stretch to me. That might be an easy test? Obviously you wouldn't want to leave it that way long term.
How much axle wrap do you perceive there to be when coasting down hill on the freeway at 70 mph in neutral?
If the vibes go away when you get off the pedal or put the Jeep in neutral, then fine. But I'm not sure I've ever heard of a vibe that had that specific characteristic. The axle wrap would have to be extremely severe to get the pinion in and out of its "happy range" dependent on load. I'm not finding this too convincing.
Is it only MC armed TJ’s with vibes?Either way, I would think it would be counter productive to use components that allow unnecessary axle wrap, especially on a sensitive vehicle.
On yours, is the pinon ever happy?
