The yj build is more of full bodied low slung bouncer for lack of a better description. As with any full bodied build, the frame and axle clearance is one of the biggest factors. Getting the frame rails as high as possible over the axles allows the whole body engine/trannyt/case to sit lower given the same up travel . We used our front and rear frame kit to not only achieve more clearance over the axle but it also is narrower than the stock frame to allow for more shock clearance throughout the suspension cycle. A double triangulated suspension was used because it travels more linear with less suspension over steer. It also allows for much more tire to link clearance when turning.
Because it is going to be beat on pretty aggressively all suspension joints are 1 1/4. They mount to 4” tubed 14 bolt axles front and rear. The weight of these axle is considerably heavier than say a 10” fabricated housing. With this build unsprung weight isnt as big of an issue as would be say in an ultra4 car where you would want a different spring unsprung bias.
We stretched the wheelbase to help with approach and departure angles and climbs.
A lower “sub frame” I’d you will not only allows you to get more vertical separation at the chassis, it allows you to do it without having to cut the tub or run a body lift. Having the “subframe” gives you a couple more valuable inches of clearance to run exhaust and drivetrain components.
We are running full hydraulic steering because of its strength and because steering input isn’t transferred through the mechanical linkage to the chassis.
The floor under the seats was cut out the lower the seats in the tub which allowed us to make a 3” lower cage while retaining the same head clearance. I only mentioned this because it ties back to the lower CG of the build.
This rig will most likely end with 6-7” of up travel as it’s the best balance of crawl/trail use. If it we’re getting beat on it would be more around around 8” and in crawling it would be set around 4” to lower the center of gravity.
This rig is running a 742 hp 454, t400/ atlas combo. Big hp for hills, big burnouts and who doesn’t like hp!
The kit has a skid plate as well as a removable tubular substructure for strength. This isn’t a little bracket you weld to the side of your frame, it’s a complete heavy duty structure that ties both frame rails together and is welded in.
The front crossmember of the kit is removable as well as the skid and tubular bracing to ease of maintenance. We’ve also included brackets that bolt in place when the front crossmember/lower link mount is removed so you can temporarily bolt the chassis side lower to so the vehicle can be moved (which really helps with small shop spaces)
Let’s see.. the front section of the skid comes with a removable front section so that an engine skid plate can be installed and still has secure mounting location as well as a smooth engine skid/belly skid transition.
It has a 20 gallon cell that is mounted behind the axle which gives you the ability to run a rear seat and ice chest/gear. Because when it comes down to it, it’s not a comp rig and will see mostly extreme trail use.
With all this said, the only reason I’m here is because someone made the comment that I didn’t know what I’m doing. I came on to ask how he came to this conclusion, not to sell this kit.
MOST IMPORTANTLY!
I will not and have not disparaged Savvy, Blaine or his experience or expertise. He clearly knows his shit and has proven it time and time again. I’m not sure if most of you realize just how small this industry is and how most players know each other.
