They didn't solve my problem, but I think my tires had cupping or other issues. The concept is interesting, but I don't use beads. As long as my front suspension is in good shape and my tires are balanced well, I don't tend to have any issues.
It's new to me. What are bead balancers? What is wrong with stick on weights.
Brian you forgot the links....
I've tried them once before but really couldn't tell you if they helped or not but it might have had something to do with my rims also.
I know some guys who actually use BB's for balancing their tires.
I've never had any dealings with them but I would imagine they'd work the sameNo one has mentioned centramatics?
If you scroll down past the last post there are similar threads.
https://wranglertjforum.com/threads/poll-did-tire-balance-beads-work-for-you.36868/
Those Centramatics sure are spendy
If they work as advertised then they're worth every penny, I hate wheel/tire vibrations
Of course the Dyna beads have been working wonderfully in the F250 for 130K miles for half the price and you cant forget to put them back in when you rotate your tires
Either way they're going to be a lot better than clip/stick on weights which my truck loves to fling off on the freeway
In theory I guess using beads would be great if you were to bend a rim while out on the trail, they should keep the wheel balanced no matter what happens to it right?
I’m running these with filtered valve stems.What kind? Counteract, Dynabead..
Thanks, I'll give them a try and they're reasonably priced.I’m running these with filtered valve stems.
https://checkeredflagtirebalancebeads.com/
what fits under a TJ rim is not enough to work for larger than factory wheels, IMO.If they work as advertised?
Yes, they do.
