New Tool Day
Interesting, I bought the ADN38 and it worked great with both my M18 Fuel drill and my Kobalt XTR 24v drill. To the point on the heavy duty rivnuts that Fluxor provides I had more trouble holding onto the thing than anything to get them started. I bet I set 100 of them though between the corners, rockers, tailgate and valance.
https://www.amazon.com/dp/B01JBHWBR2?tag=wranglerorg-20
Wonder if it’s the difference between the 1/4 and 3/8 version. I think they were about the same price but the shipping being quicker on the 1/4 was the only reason I got it.
Not sure what the difference would even be.
EDIT: maybe it had to do with the rivnuts I was using? Maybe I’ll try it in some scrap metal with different sizes.
Seemed like it would work great but as soon as they compressed it would spin no matter what the clutch was set on.
Reactions: John Cooper
What do you mean by spin? Like the whole assembly or the threaded compression rod would spin while holding the red housing stationary? The threaded rod and nutsert shouldn’t spin at all if you’re holding onto the red housing tight enough.
I’ll have to break it out and see, been several months.
Well, I’ll be damned, it had to have been the rivnuts I was using.
Had no problem getting clutch set right on either M12 fuel or M18 with a new batch of 1/4-20 rivnuts.
It definitely was that no clutch setting worked and I was having to use the drill setting, and it would spin the red section out of my hand (I’m not a little guy, you’d have to have some killer grip strength to stop either in drill).
I guess I’ll retract my statement.
And thanks @Abendage gonna save a lot of time this round, lol.
The 8mm HD rivnuts that Fluxor uses are no joke to start crushing. I’ve thought about trying to rig up one of my drill handles on the red housing for some leverage. I resorted to welding gloves and it helped but my arthritic hands were still sore as shit everyday! Glad you got it working!
I picked up Astro Pneumatic's drill rivnut installer and it's unusable for me. Neither my M12 Fuel or M18 have finite enough clutch adjustment to use it, so it either doesn't crush or it immediately spins the rivnut.
I have that one and it works great, but I DO NOT use it with a power tool. Run it by hand with a 1/4" ratchet, works like a charm.
I've seen @mrblaine make that same recommendation at least once on here. He's probably installed more nutserts than the rest of us combined. I think he said he's broken more than one of those tools, along with several mandrels, using power tools to drive them and only uses a long-handled 1/4" drive ratchet on them, and only for nutserts 1/4" and smaller. But I've tagged him to correct me if I'm mis-remembering his posts.
The first thing that happens with a power tool is the top half above the detent on the hex drive breaks off if you don't use a deep socket or get the chuck down past. The next is the tool breaks internally. I have several power tools I tried it with, not worth the hassle.
Use a 1/4" ratcheting breaker with a 1/4" deep socket and it is near flawless. The only difficulty is it is hard to hold the tool body and stop it from spinning in tight places with the larger nutserts.
There are a lot of places you just can't get the long lever handle style into and this solves that problem very well. Buy a few spare mandrels if you use it for the same size nutsert often because you will break it when you least need it to happen.
I'm 99.9% sure I purchased it based on a recommendation he made here. I do not regret it. 👍
That would definitely eliminate any clutch issue, good idea.
You get a lot of feel doing it with the ratchet, and with 1/4" drive you're not as likely to overpower the nutsert or the tool.
I modified a Milwaukee clamp style drill handle to do just that for the larger nutserts. Definitely a design flaw on their part to not offer, or include a short handle and a place for something to attach to the body.
You have it right, there is nothing clutch related inside the tool. It is just a threaded mechanism that moves the mandrel holder in and out through the nose piece. If the tool is turning, get a better holt of it.
I picked up a couple of these and they're a fantastic light for both running and working on things around the house. The hands-free voice activation doesn't require an App and works perfectly. I picked mine up in the local Home depot as part of the stuff they're putting out for the holiday sales.
https://www.homedepot.com/p/FLX65R-...rol-Rechargeable-LED-Headlamp-31323/335431380
