Good article.
https://cascadepolicy.org/uncategor...84751011&utm_medium=social&utm_source=twitter
Who’s Responsible for Oregon Wildfires?
Defensible Space Is Every Property Owner’s Responsibility
Oregon has
entered fire season earlier than usual this year, which means we are hearing repeated litanies from various interest groups. “If only we had more money to suppress fires,” says the Forest Service. “If only we were allowed to manage the forests” by cutting timber, says the timber industry. “If only people would stop driving so we could prevent global climate change,” say environmentalists.
In reality, wildfires in the West aren’t evidence of a
lack of funds, forest
mismanagement, or
climate change. They happen because the West is a fire plain, and, just as a flood plain floods, a fire plain is going to burn. For as long as we’ve kept records, about one-half to one percent of the West burns each year, and nothing we can do is going to stop it.
Caption 1: This chart shows how many acres were reported as burned each year since 1925 and my estimate of how many of those acres were prescribed burns and how many were truly wildfires. The best available data indicate that a few more acres burned in wildfires in the 1930s than in more recent years, but the difference isn’t great enough to prove anything about climate change one way or the other.
You may have seen a chart showing far more acres burned each year in the 1930s than in recent decades, which is often cited as evidence that global warming isn’t happening. In fact, it is evidence that the Forest Service was
dishonest in its fire reporting.
In 1908, Congress gave the Forest Service a
literal blank check for suppressing fires, but no money for prescribed burning. The Forest Service decided that prescribed burning was bad and it spitefully counted all prescribed fires conducted by private landowners as wildfires. This policy faded away in the 1950s, which is why the acres reported burned tapered off in that decade.
You may also have heard that many western states have suffered their
largest fires in recorded history in recent years, which is often cited as evidence that climate change is the real problem. In fact, fires have
not gotten more severe in recent years; instead, large fires are evidence of a change in firefighting strategies.
Before 1994, the Forest Service and other agencies directly attacked fires by putting firefighters on the fire front to stop fires from growing. In 1994, 14 firefighters who were directly attacking a fire in Colorado were
overwhelmed and died. The chief of the Forest Service, Jack Thomas, ordered the agency to change strategies to protect firefighter lives.
Caption 2: A large wildfire blows up in Oregon in August 2020. The little white streak below and to the right of the center of the photo is an MD-87 aerial tanker whose retardant drop didn’t do anything to stop this fire. While an MD-87 is smaller than a DC-10 or Boeing 747, they wouldn’t have done anything either. Use of these tankers is an expensive folly that kills several pilots each year.
Today, the more common practice is to have firefighters create fire lines well back of the fire front and do large backburns. One result is that fires burn far more acres but
a third or more of those acres were lit by the firefighters. Another result, sadly, is that
more, not fewer, firefighters are killed each year, but they are killed in ones and twos in aircraft crashes, auto accidents, and similar causes rather than groups of a dozen or more being burned over.
Another story is that we must regularly thin or burn forests to keep them from burning as wildfires. That’s true for southern pine forests, which grow so fast that they can become very fire-prone in just a few years. It is far less true for western forests, most of which are not made more fire-prone by suppression. Even the ones that are require a lot more years of suppression for them to become a fire hazard. A
2001 Forest Service report found that less than 15 percent of western forests are in serious fire danger due to historic fire suppression.
Contrary to timber industry claims, cutting old growth makes forests
more susceptible to fire, not less. Young trees are the most likely to burn while older ponderosa pine, Douglas-fir, and certain other species have thick bark and have dropped their lower branches, enabling many of them to survive wildfires.
Caption 3: The fires that swept through western Oregon in 2020 did not mean that forests were susceptible to becoming more fire prone due to years of suppression; they were simply fire plains that will burn when conditions are right (in this case, hot weather and thunderstorms followed by strong winds) and have done so periodically throughout recorded history. The only way to protect homes and communities from such fires is to make them defensible, as this one (where I live) is.
More people than ever (including me) live in western fire plains, and each year we hear about evacuations and homes burning down. Forest Service research has shown that, to protect homes and other structures, it is both necessary and sufficient to treat the land immediately around the structures and the structures themselves to reduce flammability.
This means roofs and eaves must be non-flammable; no firewood or other flammables should be stacked against the buildings; and 100 to 200 feet around each structure must be landscaped to minimize fire: a grassy lawn is fine; a big thicket of pine trees is not. This is known as
defensible space, and a truly defensible home and yard can survive the worst fires, whereas one that isn’t defensible is vulnerable to burning down no matter what adjacent landowners do with their land.
If you live in a fire plain, it is up to you to keep your home defensible as you can’t rely on firefighters to keep fires from reaching you. This means the Forest Service’s real problem isn’t a shortage of funds but having too much money and spending that money in all the wrong ways, such as expensive aerial tankers that, the agency’s
own studies show, accomplish very little.
If you live in a city near a fire plain, such as
Santa Rosa, California or
Boulder, Colorado, then zoning codes that prohibit low-density development at the urban fringe are asking for trouble. If a fire reaches the edge of your city, and all the houses are ten to twenty feet apart, then when one house catches fire they will all catch fire. It is safer to surround the city with a
broad zone of homes on one-half to one-acre lots that, if they are made defensible, will act as a fire break for the rest of the city.
We in the West live in a fire plain. It is going to burn. Our goal should not be to prevent the unpreventable but to adapt to it. That means making our homes defensible, maintaining
safe evacuation corridors, and strictly limiting firefighting budgets so that agencies won’t waste money and firefighter lives on strategies and tactics that are not cost-effective.
Randal O’Toole is an Adjunct Scholar at Cascade Policy Institute, Oregon’s free market public policy research organization. He is a transportation and land-use policy analyst. O’Toole has a degree in forestry from Oregon State University and has spent several decades studying forest policy. He is the author of Reforming the Forest Serviceand The Perfect Firestorm: Bringing Forest Service Wildfire Costs Under Control.
