NGP antenna with a GP?
SSTJ
Lifetime Supporting Member
SE USA
A theoretical question for our resident antenna experts.
Let's say that I have a dual-band mobile antenna connected to a mag-mount on the hood of my TJ. Now I remove the antenna and replace it with a no-ground-plane antenna. Any consequences?
In other words, will a NGP antenna work any better or worse if it is given a ground plane? (In this case, via the mag-mount and hood.) Or will it ignore the ground-plane?
Here is an example of a NGP antenna.
@Mr. Bills
@Jerry Bransford
@Zorba
If I remember my antenna theory correctly, a no ground plane antenna would ignore a ground plane because it is not in the radiation pattern. so in theory the antenna would be un-effected or potentially slightly improved.
- dont quote me on that tho. Im not an antenna guru.
Ok, interesting.
Well, I've read on two forums today that it would actually compress the radiation pattern a bit into something more horizontal, with less vertical propagation. In some cases I suppose that might actually be a good thing.
Here is what ChatGPT thinks:
If you were to attach a no-ground plane antenna like the Diamond AZ507RSP to a mag-mount on the hood of a car, the performance of the antenna would likely be compromised. The reason is that no-ground plane antennas are specifically designed to work efficiently without a traditional ground plane or radials. When you introduce a ground plane, such as the metal surface of a car's hood, it can alter the antenna's radiation pattern and impedance characteristics, leading to some potential issues:
  1. Pattern Distortion: No-ground plane antennas are designed to radiate effectively without relying on the ground plane. Introducing a ground plane, such as the metal car hood, could disrupt the antenna's intended radiation pattern, potentially leading to less predictable coverage and reduced performance.
  2. Impedance Mismatch: No-ground plane antennas are designed with a specific impedance to match the radio's output impedance. When used on a proper mounting surface (without a ground plane), they achieve the desired impedance. However, when mounted on a metal surface like a car hood, the impedance may be mismatched, leading to a less efficient transfer of power between the antenna and the radio.
  3. Signal Loss: A mismatched impedance caused by introducing a ground plane can lead to increased SWR (Standing Wave Ratio), resulting in more reflected power and potential signal loss.
  4. Interference: The metal car body may act as a reflective surface for radio signals, leading to potential interference and multi-path propagation issues, which can degrade the overall performance of the antenna.
In summary, it's generally not recommended to attach a no-ground plane antenna to a metal surface like a car hood. If you want to use the Diamond AZ507RSP antenna on a vehicle, it is best to mount it on a non-metallic surface, such as a fiberglass or plastic mount, to maintain its intended no-ground plane operation and ensure optimal performance. Always follow the manufacturer's guidelines and recommendations for proper antenna installation to get the best results.
Reactions: KingCarGuyZ
NGP antennas are nowhere near as good of a performer as those that require a ground plane. There is no reason to use a NGP antenna on a Jeep as there was on my fiberglass boats.
Reactions: Akitadog
Yes, understood, thanks.
But back to the question, which I admit is more theoretical than practical: would adding a ground-plane to a NGP antenna improve its performance, diminish its performance, or make no difference?
Don't worry, I won't actually do this on my TJ; I just want to understand.
No, that'll just unbalance it and reduce its performance.
Reactions: SSTJ
Hi @Jerry Bransford
I know we're getting a bit off topic now, but I have a follow-up question here. Why/how is it that our TJs provide a good ground plane anyway?
Here are some reasons I would think they wouldn't, so could you correct my understanding?
  • The shape of a TJ body and/or frame looks nothing like a "plane".
  • The shape of a TJ body and/or frame are shaped nothing the radials commonly used in place of a plane.
  • Even if the TJ were shaped like a plane or like radials, it's still the case that when mounted over a tail-light, the TJ body and frame are all contained in one quadrant (90 degrees) of the circle surrounding the antenna.
Thanks for any insight.
When the antenna is properly mounted and it has a good large surface area bare metal connection, not just a ground wire, it actually has a very good ground plane since the entire Jeep including its frame serves as a ground plane. Its body angles etc. don't really affect it enough to worry about. I actually considered installing a tall vertical 'flag pole' HF ham antenna for 10 through 40 meters behind my home but decided against it due to its required ground radials I didn't want to have to dig trenches for.
