Today we started to get a strange noise that was hard to localize but it didn’t sound good. We got the noise any time the engine was producing any torque In gear. Either coasting with the foot off the gas or with the transmission in neutral the sound went away. When in gear and producing any torque at all there was a rubbing or grinding sound that seemed to be independent of engine or vehicle speed. It was louder at higher speed though. It didn’t matter what gear I was in or what configuration (2H, 4H or 4L) was selected. I checked out a bunch of things but I couldn’t find anything until I removed the rear driveshaft and I think the noise went away. It is hard to say for sure because sometimes the noise would come and go anyhow. But when I replaced the driveshaft the noise, or perhaps I should say a noise came back. It sounded different this time but it occurred under exactly the same condition, I.e., only when the engine was producing torque. BTW, the universals in the driveshaft appeared to be fine. These was no binding, grating or anything else suspicious.
So what do you think of this theory? The rear diff might be starting to fail in some fashion or another? If the driveshaft is ok, as it appears to be, what else could cause the noise only when under torque and only when the rear driveshaft is installed?
BTW, this is a 2006 Rubicon with the NSD370 transmission. The rear driveshaft is a Tom Woods DC with about 20k miles on it. The rear diff is the standard Rubicon 4.10 Tru-Lok which means it’s is 1) a gear based LSD and 2) a pneumatic locker. Aside from the noise, everything appears normal.
Ideas anyone?
Ideas anyone?
