N
natsuki harvey
Guest
my 2004 jeep wrangler 2.4 l is not starting it started just fine one day 30 minutes later no luck
heres some things i did before it stopped running
changed the starter twice since the first one sparked
changed the battery since it had a bad cell
after doing those it started for about a good two days
i should also include that i drove the car to learn manual and stalled it many times...
stuck at the grocery store wer had to get our jku and strap a tow strap to it and tow it to the shop about 2 miles ago
at the shop they said that a part in the steering column is broke and that they needed to get a complete steering column to fix it
ive researched about the ignition switch and pin but what happens after the ignition switch? isnt it all electronic if so why would they need a steering column?
i will get more information and update on this as they come in...
i should also note that while changing the starter i knocked the evac line and unplugged one of the lines new the starter causing a p1494 code which the guys at the shop insisted that i need to change the pump although the vacuum line has been reconnected and there is no more vacuum noise....
thank you in advance!
