Hi all. I've read around the forums and most people have it the other way around — in my case, the 4wd hi and lo both work great, but 2wd hi isn't working at all.
I bought the jeep, 2wd worked on the test drive with the clutch feeling like it was about 95% of the way out (or maybe I am imagining this).
Trailered it about 100 miles with the front tires on a dolly and the rear on the road. When trying to move it off the dolly, 2wd wouldn't work. 4 lo/hi work, neutral works, and I was able to get it off just fine in 4 lo, with about 70% of the clutch depressed.
In neutral transmission and 2wd, the front drive shaft spins. Same in 1st gear, except it moves freely.
In neutral transmission and 4lo/hi, front and rear drive shafts spin. Same in 1st except it tries moving the wheels.
In neutral/neutral, front drive shaft spins.
In 2wd, release clutch, I hear a low tapping noise. The noise isn't there in neutral tc + 1st trans.
I have the stock linkage. The previous owner added a metal plate to accommodate the 5" lift. I've heard about the novak / savvy cable shifter mods, but I don't know if it will fix my issue. I can feel, see, and hear the transfer case linkage going into 4 hi, lo, neutral, and 2wd. I don't really have a problem with the linkage on this jeep and don't want to throw $200 at something without being sure it's the issue
Any ideas where to look around?
Thanks!
2000 Jeep Wrangler SE 4-cylinder 5-speed manual, ~4" lift + 1" body lift, NP231 Transfer Case, AS72 Transmission
Thanks!
