What’s needed to run 35 tires on a TJ referencing WranglerTjforum.com:
While I apologize for any confusion, as an AI language model, I don't have direct access to specific websites like WranglerTjforum.com. However, I can provide you with some general information based on commonly discussed modifications for fitting 35" tires on a Jeep Wrangler TJ. Keep in mind that individual experiences and preferences may vary, so it's always best to consult multiple sources and seek advice from experienced Jeep enthusiasts.
Here are some additional considerations when fitting 35" tires on a Jeep Wrangler TJ, based on community discussions on forums like WranglerTjforum.com:
Remember to consult with experienced Jeep owners, off-road shops, or Wrangler-specific forums to gather additional insights and recommendations based on real-world experiences. They can provide more detailed and personalized advice for fitting 35" tires on a Jeep Wrangler TJ.
- Suspension Lift: A suspension lift of around 3-4 inches is typically recommended to accommodate 35" tires. This lift height provides enough clearance and maintains suspension geometry.
- Body Lift: In some cases, a small body lift of 1-1.25 inches might be required to ensure proper tire clearance, especially during full suspension articulation.
- Fender Trimming: Trimming the stock fenders or installing aftermarket flat fender flares can help create additional space for the larger tires. This modification reduces the chance of rubbing and allows for greater tire articulation.
- Control Arms: Upgrading the control arms can help maintain proper alignment and improve suspension performance when running larger tires.
- Slip Yoke Eliminator (SYE): Installing a Slip Yoke Eliminator kit may be necessary to address driveline vibrations and ensure smooth operation, especially if you plan on using your Jeep for off-roading.
- Extended Driveshafts: Longer front and rear driveshafts may be required to accommodate the increased lift and prevent binding or damage.
- Steering Upgrades: Strengthening the steering components, such as upgrading to heavy-duty tie rod ends, drag links, and steering stabilizers, can enhance steering control and prevent any potential issues associated with larger tires.
- Gear Ratio: Consider re-gearing the differentials to a lower numerical ratio (higher numerically) to compensate for the larger tire size. This adjustment helps maintain power and performance, especially if your Jeep has stock gearing.
- Brake Upgrades: Enhancing the braking system with larger rotors and calipers can provide better stopping power and compensate for the increased weight and size of the tires.
As expected, it gives some good general info on things to consider, but the info lacks sufficient details...
