Troubleshooting an issue with the OEM lockers in my 06 LJR and would appreciate some guidance.
Rear locker pump turns off and on repeatedly, basically cycling every couple seconds.
Front locker works 100% correctly. I hooked the front locker pump to the rear locker and the front pump cycles.
When I hook the rear pump to the front locker the rear pump works correctly.
So now that I’ve verified both pumps work correctly I’ve determined the issue is with the rear locker. Could a leaking air line cause the pump to cycle? Maybe the interior line is damaged and slightly leaking? Guess the issue could be the internal locker bladder.
Appreciate your help.
