I'll be the contrarian here. There's nothing wrong with a Super 30 kit up front but it's my opinion that 30 spline shafts are not really needed up front with 35's, especially since you need new 30 spline hubs, bearings, and a 30 spline carrier or locker. That's a very expensive set of upgrades when there's a far less costly yet perfectly viable alternative available.
Instead, which is what I did to my previous TJ after breaking a factory front axle shaft on the trail, was to simply upgrade the shafts from the factory carbon steel 27 spline shafts to 4340 alloy 27 spline inner and outer shafts. That 4340 upgrade gives more strength than a stock Dana 44 axle shaft and it will hold up fine.
After upgrading the front shafts to 4340, my front axle had no more problems after that. Even doing the same trail again that broke the axle the first time, plus continuing to wheel other trails in Johnson Valley and other trails most would consider extreme level. 30 spline 4340 alloy shafts in the rear, 27 spline 4340 alloy shafts in the front. The front seldom sees more than about 50% of the stress the rear does so it doesn't need to have the same strength.
