Aloha TJ geniuses,
I'll make this as succinct yet complete as possible. After rebuilding my motor and transmission, my 2000 4.0 has been driving like a dream with the exception of what I believe to be an electrical problem.
As always, thank you so much for your help!
- Initially, it would occasionally fail to start but would attempt to turn over. After a few tries, it would usually start.
- This got worse and I decided to replace the starter, which solved the problem temporarily.
- After a couple months of weekly driving, it would start fine but then bottom out and die if I didn't give it gas. Sometimes it died either way.
- This also got worse but remained intermittent.
- As of the other day, it started dying randomly while driving. When I'd try to start it again, I wouldn't get the chime when I turned the key. Jeep would start after a few tries and some prolonged turnover.
- Now the chime on start up is absent even on a cold start
- Battery is new
- Fuel line is new
- Spark plugs are new
- Ignition coils are new
