We have one![]()
Don't tell Mike.
We have one![]()
Ok...any suggestions for tucking this exhaust up another inch...do they make a tighter exhaust rubber hanger? I can move the hanger up but I'd only get a half inch and the rubber would be tight into the frame.
Move the frame pin up to the inside and flip the muffler pin 90°:
Is there enough room with the gas tank?
Gonna order one of these...since it'll take a few days to arrive...as an option to French into the frame.
https://www.amazon.com/gp/aw/d/B09JZTK819?tag=wranglerorg-20
I'd grind the mushroom off the hanger welded to the exhaust and tap it 1/2-13, add a nylock...need to research melting temperature.
Insert hanger through frame and bingo.
Not doing anything until the gas tank is reinstalled...need to see if I have clearance.
I agree. Mount compliance is more important in exhaust mounting than most other component-mounting points on a vehicle because exhaust is one of the largest, most rigid components that connect between body and chassis and because the high temperatures in the exhaust system are detrimental to load resistance. You could actually see cracks appear in welds at the engine end of the exhaust due to low-compliance mounting at the tail end of the system. There is a very good reason the OEMs use the same rubber mounts on all vehicles - they are designed for high compliance, and they prevent cracks. Whatever you end up doing, keep high compliance of your mounting system as the primary objective.That won't offer nearly as much movement as the current setup.
P.S. Going with this Peterbilt hi temp exhaust bushing. I'll source my own DOM tube.
https://www.bigrigchromeshop.com/peterbilt-exhaust-bushing-high-temp.html
Following. I've talked to Blaine a little about the difficulty in getting the exhaust out the back with outboarded shocks. Even worse if you stretch at all.
