Optima batteries have a reputation that may influence how you proceed with your decision.
When you say Optima required, this is due to size? Are there other small footprint battery options?
The Motobilt fenders.
You can choose to use an optima battery box or an odyssey.
- Includes Passenger & Driver Support Brackets
If you have any questions let me know as I run the 6” high lines on the front of my TJ.
Does the Motobilt require the use of either Optima or Odyssey?
I just drilled holes and bolted my stock battery tray to the fender bracket. Works fine with OE group 34 battery.
Does the Nemesis require the use of an Optima battery?
100% yes
That would be a deal breaker right there.
Anyone have any experience with the TNT fenders?
I have just had a look at TNT, they look interesting. Nothing on the website, but from a TNT video I found a quoted weight of about 24 to 28lbs per fender. But that is for a complete inner, outer and flare. That seems impressive for steel, in fact it appears to be less than the Nemesis aluminium fender. The once piece design is a double edged sword for me, helpful for fitting but will no doubt mean the package is far bulkier for shipping. The other pro for these is that the battery bracket looks to be useable for a RHD as it does not appear handed.
I just had a reply from TNT Customs, the size of the package with the one piece fender is a big issue. It adds about $450 to the shipping cost versus a smaller package of the same weight.
What are you trying to accomplish with the fenders? Aesthetic? Legal? Performance? Some combination? For me fenders the main performance of a fender is to keep crap off my rig and keep me close to legal. Aesthetically they add or take away a lot from a rig. The stock fenders and flares look aesthetically pleasing to me and provide good performance until you bend a fender over. They can kind of get in the way. Now I have MCE. Perform well. Not my favorite aesthetically from all angles, though from some angles they look good.
Poison spyder still makes steel highlines, they are sold on 4wheelParts. Maybe look into a freight forwarder?
I’ve see lots of folks run Motobilt fenders in the trail, I think they’re a pretty standard steel option
Genright has the weight saving quality of aluminum.
Metalcloak is not a true highline as the hood line height remains the same
That's a really sensible question. At the moment I am really just surveying the options. I know that you also appreciate I have to deal with an extra dimension of dealjng with living between 3,000 and 6,000 miles away from where most TJ parts are made.
I guess it is a combination of the three. But, there is no scope for any fenders to not be legally compliant. In the UK that means an absolute minimum of 70% tyre coverage when viewed from above. Beyond that any highline will give me significantly more space above and behind the the tyre, so that is to some extent a given I believe. Of course the other element to performance is weight, with a stock engine I really want to avoid much added weight. In addition, weight has a cost influence as well. Aesthetics are not the top factor, but in part that is because in broad terms I think highlines are broadly similar in look.
Does that make sense?
I am excited to see a thread about TJ fenders that has such recent posts! I am looking to make the jump to flat fenders and trying to do some research on brands. I am not a fan of the tube look and have really been eyeing the Nemesis kits, modulus because i like the look. I like the PSC as well, but the 3" seem to be difficult to find and the bolt on replacement vs cutting lens the edge to Nemesis for me personally. The jury is still out for me on if I need highline or not. The Optima battery tray seems to be a pretty big contention point. Can someone explain why there is so much negativity around Optima? I currently have an Odyssey that I put in like 5 years ago after reading a recommendation, but I don't know a lot about the differences.
