Overlanding 2006 Rubicon Unlimited (LJ)
Chris
Administrator
Staff Member
Sep 28, 2015
33,268
20,450
Salem, Oregon
#61
Fortunately we aren’t here much longer, planning to get into a house once our lease expires in February- can’t come soon enough.
In Colorado?
Good call on buying a house. We bought out first house 3 years ago. I'm super happy we did. Now my rent can't keep going up like it was when we were renting.
rasband
rasband
LJR Junkie
340
254
Denver, CO
#63
A lot of projects have been held up by wanting to fix my battery cables being too short. I finally ordered new cables from custombatterycables.com, hoping to have time to run those this weekend.
Then I can be on to my auxiliary fuse block, winch rerun, CB wrapup (direct to battery), LED cubes, etc.
Chris
Administrator
Staff Member
Sep 28, 2015
33,268
20,450
Salem, Oregon
#64
I need to install my battery cables as well. I got new ones that I've been putting off for a while. My current ones aren't too short, just old and worn.
An auxiallry fuse block sounds like a good idea. Which one did you use? I have a ton of aftermarket stuff (transmission cooler, winch, amp, etc.), and a fuse block might be the cleaner way to do all of the installs instead of inline fuses.
rasband
rasband
LJR Junkie
340
254
Denver, CO
#65
It kind of sucks to have to do basic stuff like this than get that $150 toward a life or some other function, but suring up my base to build on over the longer term.
Likes: Chris
Chris
Administrator
Staff Member
Sep 28, 2015
33,268
20,450
Salem, Oregon
#66
Which auxiliary fuse box did you use? I have a ton of aftermarket stuff (transmission cooler, winch, amp, etc.), and a fuse block might be the cleaner way to do all of the installs instead of inline fuses.
rasband
rasband
LJR Junkie
340
254
Denver, CO
#67
I’m still early in the research, but I think I’m planning to do an 80A circuit breaker (https://www.amazon.com/dp/B000THQ0CQ/) to a Blue Sea fuse block. To wire that in I’ll do another custom cables order to get the ends with lugs.
Likes: Chris
Chris
Administrator
Staff Member
Sep 28, 2015
33,268
20,450
Salem, Oregon
#68
I'll be curious to see how you end up doing it. This would ultimately be a good idea for me, given how many accessories I have with their own inline fuse.
