I’d run a quick bypass test of the crank sensor unplugged. I don’t have time to type it out, but YouTube “crank position bypass test”. Listen for relays clicking and the fuel pump turning on when you do it. You’re just essentially pretending to be the sensor to verify wiring. Way easier and quicker than ohms/continuity checks. Also make sure your ground is good. Load it with either a test light or your probe.
