Hey group,
I have searched the forum to see if anyone is having this code on a 2.4L and haven't found a solution.
I purchased the jeep in a none starting, no click, no crank mode. Sent the pcm to wranglerfix and discovered it was bad, so ordered and received a pcm with warranty. Now the engine will start, but I am getting a p0344. It will start and idle fine, until driving, then generates a p0344 and won't run above 2000 rpm, going into limp mode.
All grounds checked and religiously cleaned, resoldered ground under the intake manifold.
Checked +5 supply and signal wire from cam sensor to pcm for continuity and damaged wires.
Replaced cam sensor with 3 different brands.(NAPA Echlin, AZ duralast, and Rockauto walker) with no luck. Mopar sensor no longer available. Finding a sensor from salvage for the 2.4L has been unsuccesful.
Someone has suggested the OPDA and a cam relearn. The 2.4 does NOT have the OPDA. And a cam relearn is not referenced in the FSM for the 2.4L, only for the 4.0. I took it to a shop with a Snapon scanner and there is no cam relearn available in the scanner options for this engine.
Someone suggested possible noise from a bad alternator. So I cleared codes, ran it without alternator and the code came back.
The timing belt is new. And the timing is NOT off a tooth. The target ring looks to be in perfect condition and has been gapped at .030 with brass feeler guage.
I am bumfuzzled and not sure where to turn next. Been fighting this issue for a month now
