Phase 1
Obie
North Alabama
77311
2001 Sport, Officially mine now!
Phase 1
New coil rail and new champion plugs
Lift: 3 inch spring lift
Tires: I have BFG AT KO 265 70 17 on hand with half tread.
Wheels: I Love the Rubicon wheel so...
https://www.quadratec.com/p/quadrat...p-wrangler-jk-jl-and-grand-cherokee-wj-wk-wk2If I've done my research correctly there will be a need for adaptors/spacers. Seems 1.25" may be enough if factory Canyon is 5.5
Advice or recommendations?
Reactions: Dre_rat and danof76
Phase 1
1.25 adapters worked perfect on my 02
Reactions: Dre_rat and Obie
Phase 1
Throw these on and you'll be good to go:
https://www.amazon.com/gp/product/B01M0BK60D/?tag=wranglerorg-20
I run JK wheels on mine as well with the same backspacing. Those adapters make them fit perfectly!
Those are nice wheel adapters too. They are CNC machined as opposed to cast, so they won't crack like some of the cheap cast ones.
Reactions: Obie and Twopoint
Chris, could you double-check the link you recommended for spacer/adapters?
The numbers work with my calculations but TJ is not mentioned. Liberty and Grand Cherokee are.
Just making sure.....Thanks!
I do like these.
I do like these.
They work. Those are the exact same ones I run, same link and everything.
Reactions: Obie
