Good morning, all.
I'm trying to diagnose a new sound (as if there weren't plenty of sounds already) coming from my 1999 Jeep Wrangler 4.0 TJ. A few days ago I started hearing this almost asynchronous grinding/whining sound when I have the vehicle in gear and giving it gas. It would occasionally chirp when held at constant speed, though I think that's from hitting small inclines where the load increases, though listening very carefully yesterday it almost seemed like I could very faintly hear it when not under load, but this could be in my head. The sounds cuts out when I'm decelerating and when the clutch is pressed in.
From my several hours of googling and searching it seems like it might be the input shaft bearing. I'm not seeing much in the way of write ups, which worries me. My questions, if anyone can help:
For reference:
4" lift kit, 33 x 12.5 tires
Ford 8.8 rear end
Driveshaft with low-mileage u-joints
- Do I have to pull out the trans to change this? It seems like this might be a full tear-down situation, which is far, far outside of my budget at the moment.
- Is there any way to confirm it's the input shaft bearing and not something else? Could something else cause similar symptoms?
- How long can I drive it like this? I know any figures would be estimates, of course, but as I'm having to very very quickly move out of a bad situation I'm in and this being my only means of transportation for a while I'm sort of stuck without a vehicle if this goes down.
- If I do have to have the transmission pulled out, is there anything else I should have done while in there? If I have to go through the costs associated I don't want to pull this out again for a while.
For reference:
Ford 8.8 rear end
