This and a K&N air filter and it's off to the race track !!!!
I'm likely getting around 300hp and 350 lb-ft of torque @7 psi with Banks turbo (flywheel). If my kit was stolen today, I'd likely buy Jezza's turbo kit bc the extra power really makes a difference in drivability & enjoyment. This is my first boosted vehicle and I'm hooked.
That's next. Im waiting on Barnes for my truss. 5.13 gears ok at 70 mph?
I would love to see turbo(or supercharger) and stroker dyno charts on the same graph. I'm assuming the turbo does more for power than my stroker.
Every once in a while i think about removing my pistons and having the reliefs cut to a turbo friendly compression ratio. Yeehaw!
I'd like to see that too just for the fun of it. I bet they are pretty close in power but may feel different based on the stroker's power being more linear.
With the 35's and wheels, the power plant doesn't feel anything like a modern sports car, but ramp runs and steep inclines are really fun now rather than a burden.
My gut doesn't trust the stroker/boost idea holding up for my needs and budget, otherwise I'd have that feeling often.
IIRC, Jezza said something to the affect that being around 300 hp with the turbo'd 4.0L was a good combo regarding power and reliability.
If i have forged pistons and rods why not a lil boost?![]()
I'm all for you making something awesome and doing what makes you happy. I just don't want to see it grenade on you.
Wait - I have forged pistons, rods and crank. Hmmmmmm….
- Cold air intake (flow = go, as @custommuffler would say)
- Throttle body spacer (stack 2 or more of these for a real power boost)
- 86-port injectors (basically the more ports the better)
Really good for Brule but that really sucks for the rest of us.They've got a spot open. Steve Brule retired and as of now there won't be another season.
-Mac
Installing the correct gears for your tire size will make the largest difference. The I6 4.0 is only 190 HP, so it's not a hot rod and will never be 'fast'. The only thing it does that is fast, is drink up all your gas.
Never fast, but certainly quick!
Edit: Joking aside... 5.13 for 33s? For a wheeler sure, but not a street truck...
