So they bump from 2000 to around 3000 if your throttle doesn’t increase when u turn OD off.
They shouldn’t drop back down to 2000 if you are still in third gear at the same engine and vehicle speed. This is a good point for us to confirm what’s going on.
This is when RPMs should drop to about 2000. If they were dropping to 2000 with OD still off and then jumping to 3000 when u switch OD back on then I’d be checking to see if it’s going into OD when u have OD off which then may cause OD to turn off and go into third when u switch OD back on.
Btw my $130 thinkdiag2 device from Amazon tells me my gear. You can use the device to select TCM data and select the gear, if OD is engaged, if you are in lock up, and can also track your engine speed (and more) all on the same screen.
It doesn’t do freeze frame but I got around that by doing a screen recording of my phone when it reports live data. That’s how I’m proving my current OD issue to the tranny re-manufacturer otherwise I’d be SOL with no credibility.
Here’s a short example of what I was tracking yesterday per the remanufacturer’s request.
