Use a DOT 3, 4, or 5.1, do not use a DOT 5 which is incompatible with the brake system. If you see a synthetic DOT 3 or 4 or 5.1 go for it but otherwise a conventional is fine. Prestone and Castrol are two good manufacturers of synthetic DOT 4. Keep the bottle closed except while pouring it to prevent moisture getting into the brake fluid which soaks up moisture like a sponge.What are the best tools, method and fluid type and brand -thanks, Andy
To quote Moneypenny in Skyfall as she shaves James Bond, sometimes the old ways are the best. Our resident brake guru/expert/brake system designer @mrblaine often still pumps the brake pedal when bleeding the brakes.Best tool is a vacuum bleeder. Pumping fluid with the brake peddle is old school.
Not quite often and still, only. I've not found a great way to seal the threads on the bleeders yet and given the effectiveness of manually doing it, I'm not sure I'll spend much time looking for that answer.To quote Moneypenny in Skyfall as she shaves James Bond, sometimes the old ways are the best. Our resident brake guru/expert/brake system designer @mrblaine often still pumps the brake pedal when bleeding the brakes.
Awesome. I run 33,s , are black magic pads noticeably better?
Very, they are significantly better.Awesome. I run 33,s , are black magic pads noticeably better?
I can't use them. I've tried but I need to be at the wheel cylinder to see what is going on and diagnose the system and any issues that way. The only way I can do that is at the corner.One more question ..are the one way brake nipples worth the money if you have to bleed solo later?
I needed some nipples , it's like 3.00 dollars a pair for stock ones and 14 a pair for the "quick bleeder" one person style.
Andy
Note that I did not say they don't work. I just can't make them work for the way I do things.Thank you .
