My radio fuse remains powered until I touch, trigger the windshield wiper, then it powers down any ideas?
Could it be the electrical part of the ignition switch? I did replace the mechanical portion of the switch in the steering columnNo no dash work in over a year
After I pulse the wiper the radio does not power up, or shuts off if it is on.. I also just replaced the unblown fuse to no avail.
I did replace the mechanical part of the switch as the shaft had broken to the switch, and didn’t turn the electrical portion of the switch any longer (a very typical problem I have learned). I was able to start it only by removing the cover from the starter relay and pushing the switch plate in the relay by hand.Okay, I am sold on a bad ground as they cause funky electrical issues.
Since you did work on the ignition switch, I would check the ignition switch harness to make sure it is fully connected, and to follow the wires to make sure they are not pinched anywhere - after you closed her up from the initial ignition switch work.
Also, did you replace the ignition switch, was something wrong with it?
