Just completed the break in on my new 5:13s. Thanks all for this recommendation over the 4:88s. So far, I am very pleased. Even with the 5:13s the overdrive on my trans shifts in too early but it is MUCH better than it was. I am also running 33s and my speedometer was reading 72 when the TJ was traveling 60. Since the gear replacement will not work on the TJR, I went with the Speedo Healer by Blue Monkey. Pretty straight forward plug and play; however I did not run the cable up the passenger side as indicated in the instructions. I felt it was way too close to the exhaust and in the engine bay too close to the ignition. I ran the cable up the drivers side as seen in the pics. The programming was also pretty simple. Hopefully, it will be waterproof as indicated. Pretty pricey at $160 but I thought it was the best and simplest option.
