I just went from 4.10s in my 04 Jeep Rubicon to 4.56s. Has a 4” teraflex lift and 35” discovery tires. It now has the vibration at 50+ like the core of this thread describes. Prior to that it drove perfect. Has anyone tried going back to 4.10s and if so did that fix the issue? I have many concerns having the shop try and resolve this issue and making too many changes if they can’t fix the issue and it doesn’t sound like anyone has figured this out for sure.
Is it worth letting the driveline shop it’s at keep trying to figure this out or cut my losses and go back to the way it was? I just worry the vibration will now still be there going back to 4.10s since things have already been messed around with.
Thoughts?
4.56 is still a pretty uncommon ratio to get the kind of unsolvable vibrations that @bobthetj03 has (though I believe that’s his ratio too). Start by going over your driveshaft u joints and make sure they are good. Check pinion angles. The faster the driveshaft spins the more sensitive to pinion angle it becomes.
You mentioned a 4” lift. Do you have a double cardon driveshaft? TJ Rubicons almost require that (and adjustable upper control arms, minimum) to handle 4” of lift. LJs, with their longer wheel base, get away with more.
