BendLarry
And please take no offense, but using a steel wire rope (cable) will be much better than a nylon rope.
The Readybrake uses a cable not a rope.
I still have not installed mineI think @Rob5589 is running your setup. Let's see if he chimes in.
I'm gearing up for my annual 2 week camping trip to the Sierras with the TJ. I've got one week to be ready. Reading the posts on towing were especially helpful and I'm working out the configuration of towing the Jeep. One problem I see is that the ReadyBrake cable isn't going to clear the ball latch. I have the cable mount on the Jeep 6" higher than the tow points. It's a standard tow bar. Smittybilt. Somehow, the truck must be able to make a turn that doesn't cause a pull on the cable. My opinion right now is that ReadyBrake is not compatible with standard tow bars.
Anyone?
You guys are confusing me. If Ready Brake sells a riser for Blue Ox applications how can they say no rise/drop between the brake and towed vehicle?
I'm just trying to learn what my options are for flat towing and now I'm more confused than ever. Maybe I should just buy a Brake Buddy and call it a day.
So it's all about the physics. The toad surges forward when the tow truck brakes. That's what causes the lever to lift and the brakes on the toad to engage. The force needs to be linear, that is, in a straight line from the toad hitch to the brake unit. If you have a drop between the toad and the brake unit, the force will be less. It will want to pivot.
I wish you the luck of CL, I never seem to have any. If I found a BreakBuddy when I needed a tow setup for $300 I'd be singing too. I'll give you an update after I put 1000 miles towing this, but I think I've got it licked. Actually, the only advantage I've heard of the $1000 (retail) units are they're easier to hook up. I've dropped the hitch directly on the ball twice not using a stick marker. No advantage, (maybe).
Finished my San Diego to Mammoth Lakes trip yesterday. My truck is a beast and had no trouble with the Crimson Toad. Here's my 2 cents on the standard tow bar with the ReadyBrake. It sucks. First off, there are 3 separate pieces with pins. Drop receiver, Ready Brake, and ball receiver between the truck receiver and the tow bar. Each one has about a half inch of up and down wiggle, so when you do stop and go traffic, the whole works has an inch and a half play. Bam! You can feel that. I think that's just the stress BendLarry is concerned with.
The next time I tow, it will either be a complete manufactured unit or just a bare tow bar. The ReadyBrake should not be used like this.(my opinion)
As for the legal aspect, it appears to me CHP, etc, are not enforcing the supplemental brake law. Has anyone on this forum had actual side of the road experience with this? The law barely seems concerned with the 55mph speed limit on towing.
OK, so I installed mine last night and set it up today. Yea, it doesn't work, just like @DHunt and @BendLarry already stated. For one I have to use a 4" drop hitch flipped upside down which does not allow the cable to run parallel. The other issue is all the joints between the truck, RB, drop hitch, and ball. All sorts of clunking and banging. It also takes a great deal of pressure to compress the RB. It may work if everything was level/inline. So at this point, need to find another solution.
I don’t think I ever said my Readybrake didn’t work. I took a 1800 mile trip with one and it worked. I have a bigger raise than you do and I got the cable straight. I also drilled and tapped a couple of bolts in the component junctions to take out any movement. I had no clunking. I didn’t stay with the Readybrake for two reasons. First, because of the addition of the raiser with the Readybrake it made my total tow bar setup to long. Second I feel the Jeep is too light for the internal Readybrake spring. It only activated a few times on my trip. It is a good cheap legal solution but not the best solution for my setup.
