There is nothing better for towing than a diesel rig. Plus, the diesel rig won't lose much fuel economy when towing, but this is off track from the original post.
Yo, CodaMan Is Tow/Haul Mode and transmission/engine braking Is that a chip upgrade option? I don't know that I have anything after market like that on my truck. This was the first time I used it for towing. It seemed alright, but I don't know everything there is to know about it.
2002 F250 7.3
So I decided since I am stuck with it, I'd experiment a bit. I am going to run a 10" hitch riser to level everything up, run a fatter cable to eliminate any stretch, and a turnbuckle to make adjustments easier. Will it work, hell if I know. I figure for 20 bucks may as well give it a shot. I wanted a hitch riser either way to lift my hitch hauler up and out of the rocks so no loss there if it doesn't work out. The other option is something like the SMI but the is 950 bucks I don't have to spend. I tried to talk the wife into a new truck. She gave me the, "F no," look
A new diesel will cost me 100K. 60 for the truck and 40 for "her new kitchen." :meparto:Can't talk her into a nice diesel truck huh? LOL
Probably right. Just hoping for some good luck. Either way I had to do something because I was too far from the 2" from level that is recommended. More like 4" by the time the truck is loaded down with gear. Riser here tomorrow so fingers are crossed.I think you guys are overcomplicating things. When i installed mine, all i did was get my tow bar as close to level as i could and install with the included parts per the instructions and it worked as advertised. I did add a stainless steel turnbuckle thinking i might want to find tune the tension.
I have a low to the ground class C motor home and a Jeep with a 5 inch lift and 33 inch tires which meant I needed a 10 inch receiver lift. I didn’t modify anything else. The parts that came with the assembly worked just fine.
Well, I am only about 90K short. She is so hard to deal with :meparto:So what's the problem? You're getting the better end of the deal LOL
